- Thread starter
- #221
Good looking young man you have there, bet he's good help too.
Thanks Gator. Thats one of my many nephews. While I do not have any young 'uns of my own there is usually one or two nephews around here on the weekends to lend a hand. Joe is the youngest but he is also mischievous . . . he likes to hide important components when you need them the most!
Those will be great tires.
Hoping so; those on the board that have them seem to like them.
Is there a better way to balance then beside the lip weights?
Not sure; I had thought about the potential for using stick on weights as well. I did not have a chance to talk to the tire guy directly this weekend but will ask him about it this week when I take the rest of the rims up for mounting.
Nice exhaust gasket. Is that the original?
Not OEM or the original. I always use a new intake/exhaust gasket when pulling the manifold if it has been on for any length of time. Back when I started this adventure I did not know any better and ordered a few things from $OR. I was thinking about the manifold separation/alignment issues and this was supposed to be their special graphite gasket that would compensate for mild unevenness. In hindsight I think it is just a remflex gasket with a more expensive price tag. Specter has a lot of pieces available but they sure like their parts (and price them accordingly). They lost my interest/business when I wanted to order OEM front turn signal units and they told me I should order aftermarket pieces instead because my truck has an aluminum tub and is not a "true restoration." That may be true but they sure were snobby about it. . . now that I am enlightened to the resources available here Id much rather give my business to the vendors that contribute to the MUD forum.
As for today it was a back and forth day of productivity between the shop and greenhouse. As far as the greenhouse goes I must have filled several hundred pots with topsoil. . . we had a production line with pot fillers, planters, waterers, pot hangers, etc. At the end of the day all of the plants have new homes and mom can focus on maintaining them. The greenhouse started out as mom's hobby but it has become a fun little side business for her. . . they just put an addition on this past year to try and keep up with demand.
In the shop I was able to torque down the manifolds and bolted a few more pieces to them. My exhaust is just the down pipe and stops somewhere under the driver's feet. It should work for now; once I know the engine runs/truck drives I can haul it up to the local muffler shop here in town for a proper tailpipe. Cleaned up, painted, and installed the fuel lines. Also fitted the spacer/insulator plate and carburetor desmogged/rebuilt by Jim C.
Quick question for @FJ40Jim -- when I sent the carb off I think it had a carburetor temperature sensor on it. . . is that something that is considered part of the desmog? I was going to put the carb cooling fan back into service and I imagine the temp sensor is a component that provides feedback for the fan. . . I think the sensor lives in the tapped hole at the base of the carb, but its empty
I also assembled and installed the pedal hanger and several other firewall components. Started getting more serious with the wiring harness and installed a few pieces because I knew where they went. Need to refer back to the old pictures so I can put the rest of the knobs/switches back in the proper place. The gauge cluster is not in for good. . . just test fitting and wanted to see how things looked.
I did pull the gauge cluster apart so I could clean everything up on the inside. There were a few patches of superficial rust on some of gauge faces so I tried to clean them up/paint them as best I could without covering over the lettering. I also taped off the glass and painted the outside cover a fresh coat of silver.
Again, the fasteners are not tightened down -- just test fitting to see if I like the color combination.
Overall another good day. Looking forward to getting after the rest of the tires this week. . . and adding a few more pieces to the engine bay. It is starting to get get a little crowded in there and a lot more still needs be added!
