- Thread starter
- #121
Next was the installation of the new rollers to the inner input shaft where it will ride on the output shaft. A good bit of grease helps hold them in place as well as a snug fit. . . I was worried that they would all drop down into the bottom of the transmission case when I went to install the shaft but they slid in fine.
A little tapping with the brass hammer had the input shaft installed in no time. Luckily I did not forget to install the new synchronizer.
Next I moved onto the counter shaft bearings. The front bearing matched up to the original just fine but there was something different about the bearing at the back of the case. It took me a minute to realize the bearing came with a new roller flange on the inside -- it was at this point that I also realized I had not removed the old flange from the counter shaft. I thought I could get away with leaving the old collar/flange on the shaft and just putting a new bearing in place.
I thought that I might be able to get away with using the new bearing on the old collar/flange, but there are some differences between the two in terms of roller/spacer thickness (new = shiny silver, old = goldish tint) so they will not just swap out.
This is where I left things for the night. I figure my options are to reuse the old bearing (last resort -- no point in putting one old bearing back in with everything else new), or try to remove the old collar/flange from the counter shaft WITHOUT having to pull all the pieces back out of the transmission again. I think if I heat it up with the torch I should be able to get it to slide off with what access I have. Stay tuned and we will see what tomorrow brings. . .
