- Joined
- Jun 6, 2005
- Threads
- 74
- Messages
- 1,392
- Location
- Jacksonville Beach, Florida
- Website
- exitoffroad.com
Sharing our leaf spring options here, as we've had a few people ask this week about what we offer for the FJ40's. We are stocking this in the USA too, in Miami FL
We still make the small and large eye leaf springs, so for those looking to restore or reuse OE shackles, or maintain the original smaller 25mm eyes, we have springs for those, as well as the later model 35mm eye sizes.
A couple of quick points:
1. Our leaf springs can be used with stock bushings and stock shackles, so you don't have to use our bushings if you don't want to.
2. Our poly bushings can fit into stock leaf springs.
3. Our shackles and pins can be used to replace stock ones if desired.
4. Accessory load has to be strongly considered before ordering leaf springs to make sure the correct parts are ordered, and that the ride quality and lift height will be correct once installed.
25mm Spring Eyes - Early models
Front - HJ40-7L-F - 7 leaves, 45mm Lift, Standard weight
Front - HJ45-7L-F - 7 leaves, 45mm Lift, with 200KG (440LB) constant accessory load to suit bullbar and winch
Rear - TOY-034-R - 6 leaves, 45mm lift, Standard weight (has 25mm longer main leaf), suits soft tops
Rear - TOY-029-R - 7 leaves, 50mm Lift, with 150KG (330LB) constant accessory load (hard top, etc), 25mm longer main leaf
PB59-1013K - Poly bush kit to suit front or rear leaf springs, 1 kit needed per front or rear, 2 per vehicle total. Can work with stock shackles and Dobinsons shackles
SK59-002 - Greasable shackles to suit 25mm spring eyes, 4 needed per vehicle. These are not anti-reverse shackles.
SP59-006 - Greasable fixed end pins to suit 25mm spring eyes, 4 needed per vehicle
UB59-450K + UB59-453-3K - Front left and right side U-bolt kits, need 1 of each per vehicle
UB59-453-3K - Rear U-bolt kits, need 2 per vehicle
GS59-635 - Front twin tube shocks
GS59-635 - Rear twin tube shocks pre-1975
GS59-651 - Rear twin tube shocks post 1/1975 models
SD59-823 - Replacement big bore steering damper with all new fittings
Full kits for early models: Dobinsons Full 2.0" Suspension Kit for Toyota Land Cruiser FJ40 BJ40 1960 to 1979 | Exit Offroad
35mm Spring Eyes - Later models
Front - BJ42-7L-F - 7 leaves, 45mm Lift, Standard Weight
Front - HJ47-7L-F - 7 leaves, 45mm Lift with 200KG (440LBS) constant accessory load to suit bullbar and winch
Rear - TOY-035-R - 6 leaves, 50mm Lift, Standard weight, has 25mm longer main leaf
Rear - TOY-036-R - 7 leaves, 50mm Lift with 150KG (330LB) constant accessory load (hard top, etc), has 25mm longer main leaf
PB59-1019K - Poly bush kit to suit front or rear leaf springs, 1 kit needed per front or rear, 2 per vehicle total. Can work with stock shackles and Dobinsons shackles
SK59-047 + SK59-048 - Greasable shackles to suit 35mm spring eyes, left and right anti-reverse, 2+2 needed per vehicle
SP59-007 - Greasable fixed end pins to suit 35mm spring eyes, 4 needed per vehicle
UB59-449K + UB59-453-3K - Front left and right side U-bolt kits, need 1 of each per vehicle
Full kits for later models: Dobinsons Full 2.0" Suspension Kit for Toyota Land Cruiser FJ40 BJ40 1980 to 1984 | Exit Offroad
Also attaching the application pages, so you can see the full breakdown, which is the same that I wrote out above.
For 45 and 47 series, shoot me a message for those application pages.
