What if I was to inform you Scott Dixon used soldered terminals to win the Indy 500?
rsbcruiser, where do you find these "common" metal/rubber loops?
I must be living a third world country, never seen any (I know where to get the "common" plastic ones used in electronics, though)
It has been "playing on my mind" that technique with both soldering and crimping is as important as having the correct tools.
(By the way - My big heavy battery leads are "crimped only" and I have no complaints with them! So I am not advocating soldering for everything.)
And I was recently shocked to see the "poor soldering technique" used by the editor of a 4x4 magazine over this way. His technique was being displayed "as an example for others to follow" as he showed us his installation of spot lights on his rangerover.
And his techique as I recall (I've given away the mag), was to twist the wires together like this for soldering:
Then he said he would wrap those joins with insulating tape.
Well insulating tape of the type used in my picture will ALWAYS tend to unwind (and risk exposing live wires to short-circuiting). This is why most of us go for heat shrink sleeving. (A trap we all fall into though is to forget to slip it on the wires before soldering.) You can of course (and I do) prevent this "unravelling" by securing the end of it with a light-duty cable-tie. But trying to protect something horrible like "this spike protruding at right-angles to the line-of-the-wire" is prone to failure anyway.
Here is a photo of my wirestrippers at work. They can remove the insulation easily without damaging any strands:
And such a joint should have really been done like this in my opinion:
Double barreled ring? Like this?
just picked up a can of lenox ... water soluble flux...
Water soluble flux is one the most corrosive types. It is used extensively in the manufacture of printed circuit boards and soldering pipe. Applications where the finished solder joint can be cleaned.
You live back east where it's good and humid right?
Have you read the thread?holy crap.. i haven't made one good idea so far lol...
what would you suggest...?
holy ****.. i haven't made one good idea so far lol...
Dude just resign yourself to doing what I have been doing since this thread started. Sit perfectly still, do or buy nothing, read intently the words of Crimpy McCrimperson and the other masters of the fine Jedi arts of soldering and heat shrinking. Take notes, THEN make a buying list going to the recommended places and then practice the hidden arts assiduously until you too can enter one of the two great houses of cruiser electrical work.Have you read the thread?
I'd recommend a quality pair of crimper and some good heat shrink style connectors.
Sorry, not double barrel ... open barrel like in this pic. Those are spades with an open barrel ring mixed in.
Oh! Now I know what you mean! One set of ears crimps the insulation and the other set crimps the wire...
Those spades actually look like relay terminals? Waytek carries those in 1/4" Part #31073 for 16-14 ga wire # 32074 for 12-10 ga wire.
I looked through three suppliers catalogs and did not find the ring terminals in the double crimp style... I'm sure their out there though!
They do make an insulated version (Nylon Insulated with extra sleeve) Look at part number 31704. It has to be double crimped...
I don't have a crimper for that style anymore. Mine was worn out and I never replaced it. I haven't seen that style of connector for a long time, I'll see if I can find a source.Oh! Now I know what you mean! One set of ears crimps the insulation and the other set crimps the wire...
Looks like the 12XX series on this page:I don't have a crimper for that style anymore. Mine was worn out and I never replaced it. I haven't seen that style of connector for a long time, I'll see if I can find a source.
