Disabling the AHC and AVS systems, no warning lights. (10 Viewers)
@turbo8 Do you have one of the front OEM struts disassembled?
Need some measurements of the factory front coil spring.
Free height -
Top of coil inside/outside diameter -
Bottom of coil inside/outside diameter -
Exploring aftermarket spring options for my LX570 while retaining AHC.
Thank you
I don't have them disassembled, I can when time permits though.
Completely understand, and that would be awesome.
Spring rate would be a great nugget to have
If your talking about my thread hijack, I can't remember if it was in the tundra swap thread or another, but a different member said he was working with someone for different springs and was waiting on them or something but I asked if he knew the factory rate, and said it was 230lbs. Where that came from, I don't know. But seems like it could be fairly accurate given the rest of the system.
As long as the factory spring doesn't have any abnormally crazy measurements, we should be able to locate aftermarket springs fairly easy. Worse comes to worse, I'll eventually just buy one replacement coil or buy a salvaged one to disassemble and have tested. But for that price, I can get two brand new aftermarket coil over springs and roll the dice too. Eventually I plan on just increasing coil rate 100lbs/inch or so to deal with my front bumper, and eventual winch. Will probably do the same in the rear too.
This worked. Vehicle lowered another inch and the suspension works now!
As it's a CANbus architecture, there's a module somewhere simply relaying that information about the missing module it's expecting (maybe the instrument cluster module?) The PCM's (engine and trans) are likely the same between the LX/LC/Tundra 5.7 just from a parts production perspective.
Are the different computer modules amongst the systems the same between the LC and LX except for where the AHC stuff is concerned? If the other modules in the car share the same part numbers between LX and LC, new opportunities abound. New dash module that is a LC so it's programmed to be ignorant of the AHC ?
It is CANBus. We have swapped a number of components between LC and LX without being able to get the codes not to show up. We have not swapped an instrument cluster but not really sure that is viable. We can't figure out what module is telling it to look for the AHC inputs. We need someone that can talk CANBus to work out what needs to be done.
It looks like it will be sitting like this.
Did you measure fender to wheel center before lift, in N for example?
It sits around 23.5" now. It was much lower before, but I don't have a measurement.
Vs 4runner
The Lexus should ride a lot better.
4runner is pretty harsh with the amount of lift it has.
Inst cluster is fine the more I think on it. I had to deal with canbus on a GM E38 DBW to chat with a arduino uno I had to control AC requests and cooling relays.
As long as the CAN lines can be tapped somewhere near the main brain; you can record the traffic since CAN is untargeted broadcast messaging. Then while recording all the traffic (its not a very high bandwidth protocol) one could test the AHC functions, and throw a switch to disconnect the AHC and record that. Further, there may be a simple "are you there? Ack/noAck request" and you flood the frames consecutively. Its been 3 years since I played with canbus programming so im hella rusty.
Yes itll be tens of thousands of messages a second, but it can be filtered down. From that point; a simple arduino module can be installed and spoof as the modules.
Over on a few bimmerboards: a guy named Thaniel helped advance this ball mightily on GM to BMW canbus chatting and translation.
This was always my prevailing idea so long as Toyota didnt gate keep behind an odd protocol spec. Hunch is no oddness based on "ignorant" the overall car reacts to missing modules.
I talked to mt4x4 on this. They commissioned a module for the 100 ahc. To get it updated the programmer was in five figures just to get started. Wasn’t going to be commercially viable. If we shareware it that could be interesting. I reall6 like the abc, but for the very long term it would be good to have some options. Ecus don’t last forever. Globes might increase in price, etc
Dropping all the ahc junk.
Silly amount of bolts holding everything together..
Will you be able to snake the hard lines out without destroying them? Could be good info in the event someone needs to change on in the future.
I don't think you can snake them out. The lines appeared to be put in place before the body was dropped onto the frame.
I cut the front ones out and looks like I'll need to cut the rears out.
The hard lines are pretty thick walled with rubberized coating.
Removing the stock shocks sucked. Decided to cut the shock shaft cover off to see what the shaft looks like.
