Thanks for all the comments, even from the DICKS
Unfortunately, I'm not going to pay much attention to the one from people that don't live with snow on a regular basis.
I admit the tires are stock LTX m&s and "All Season" tires are for all season in the Southern US. They do not handle snow or ice at all.
I think that it's a known fact that ABS is not designed for snow & ice. A competent driver (which my wife is) can easily stop better in snow than the best ABS system. Threshold Braking will do wonders in the snow. The only thing that ABS does well is preventing the back end from locking up and spinning the vehicle.
If you're used to just stomping on the brakes with 2 feet you will skid in snow for a very far distance. The secret is to apply the brakes gradually, staying above the threshold of locking the wheels and/or pump the brakes. The ABS will pump for you, but too quickly and constantly locking the wheels because you are applying too much pressure and you can tell because everything is vibrating.
This is from the CANADIAN Government:
Is the stopping distance shorter with ABS?
No! From early commercials, it may have looked like you could stop on a dime. That instantaneous stop is not realistic. When braking on dry or wet roads your stopping distance will be about the same as with conventional brakes.
You should allow for a longer stopping distance with ABS than for conventional brakes when driving on gravel, slush, and snow. This is because the rotating tire will stay on top of this low traction road surface covering, and effectively "float" on this boundary layer.
A non ABS braked vehicle can lock its tires and create a snow plow effect in front of the tires which helps slow the vehicle. These locked tires can often find more traction below this boundary layer.
Another:
If I live in the Snow Belt, how can I benefit from ABS? Even in fresh snow conditions, you gain the advantages of better steerability and stability with four-wheel ABS than with a conventional system that could result in locked wheels.
In exchange for an increased stopping distance, the vehicle will remain stable and maintain full steering since the wheels won't be locked. The gain in stability makes a potential increase in stopping distances an acceptable compromise for most drivers. All in all, these benefits outweigh the rare instances where the ABS system increases distances over non-ABS equipped vehicles.
I don't doubt the stability, but if you have to stop and have no where to go... Guess what? You have to stop.
