Landy,
I'm sure going to the university on a steep road taught you some things about slippery braking that will benefit you the rest of your life in snow driving. But you're absolutely wrong that downshifting is a good way to deal with slippery conditions. Let me explain just one reason.
When you downshift, you are getting a certain level of braking force - let's call it X. For the conditions you're on, X may be too much braking, or it may be way too little braking. Or it could be too much initially, then taper off to way too little as vehicle speed drops. But there's no way for you to change it - that means there is zero modulation.
On the other hand, you have a brake pedal that can instead exert braking force. With the brake pedal, you can brake at X, 1.2X, .80X and any level you would like and you can change (modulate) it several times a second if you wish to maximize your deceleration. So, for your theory of downshifting on slippery stuff to be valid, it would have to have the magical ability to go right to the correct level every time you did it on every surface at every speed you chose to do it, etc. This is clearly not the case, is it? Seriously, man - you are giving advice that is downright inaccurate at best and dangerous as well.
Here's something else to chew on. You've stated yourself many times that threshold braking is best (which I agree with) - so how do you square that with your downshift theory where the level of braking is quite random and may be WAY off the level needed for threshold braking? In point of fact, it would be absolute sheer coincidence for the level of braking from downshifting to be threshold braking. Threshold braking requires continuous adjustment of the pedal pressure as the vehicle speed changes and the surface changes. So your method can't do threshold braking by definition. So which is it - threshold braking is best, or downshifting is best because I can tell you that you cannot use both. Were I you, I'd pick the former theory and give up on the latter.
I appreciate your input based on where you attended college. However, I'm telling you my viewpoint based upon years of involvement with vehicle design and engineering, as well as having been GM's Worldwide Powertrain Planner, and having participated personally in the design, execution and data analysis of performance evaluations for all manner of traction controls, ABS, and AWD on controlled artificial ice and real ice. I've been to ice driving school. And to top it all off, I once drove a Triumph Spitfire through a Michigan winter with an engine stuffed into it that doubled the horsepower!!!!!!!
For the love of Pete, man - downshifting on ice or any slippery surface to slow the car instead of using the brakes is a bad strategy to use.
Sir Disagreeable
