Cruiser 100 Series - Family Overland
Please describe the way that happened to your front diff - were you using ATRAC and flooring it? Or, were you locked and...? I'm only asking so I might escape the same fate (I'm an offroad noob). I understand that the 99 had a different front pinion from the 2000+?
I enjoy asking and answering questions...
98-99 do not have ATRAC. Diff-Lock was switched on and the rear locker was engaged. Medium throttle, light snow. Granite rocks under snow.
The only difference in the 99 vs 00 is the spline count on the pinion, which does make it stronger, but not enough that you could have avoided the same fate in the same conditions. (Correct me if I'm wrong on the spline count. I replaced my ring a pinion with one out of a 2001 while doing the rebuild.)
Other than the hassle I was happy to replace the factory diff. The factory cage is weak, along with the spider and side gears, and cannot keep from expanding and snapping under moderate HP and pre-loaded stress. Perfect storm.
In the image below, parts labeled 8, 11 and 12 are the weakest point in the LC100 running gear. The ARB locker I used to rebuild the diff is both stronger and cheaper all told, unless you can find a used complete diff to swap out.
Details:
We were in light to medium weight snow, most of it about 4ft deep except where the wind had blown it around. Where I tore gears apart was in a section that was about 16" deep. I am not a heavy throttled driver, prefering to finesse through difficult sections. I was using a medium throttle and progressing slowly through a drift but could not see well enough to know where the granite rocks were underneath. (I have driven the section about a dozen times with and without snow.) The straw that broke the camel's back was, when with a bit of wheel spin it caught the edge of one of those boulders. Banging and popping ensued. I immediately backed off and worked on getting us back down the mountain.
As a matter of advice: Initially I assumed that I had broken a CV axle, so I switched off the Diff-Lock. The banging occured with greater frequence. I then switched the DL back on and it almost entirely went away. (It makes sense now.)
Another little mod I put in our Cruiser a couple years ago that has made life easier as we travel, is the cargo net above the mid row seats. All of our jackets go up there and are easily accessible.
Originally I purchased them from SPORTSMANSGUIDE.COM, but they are out of stock (This is unfortunate because they were $14 for 3 plus shipping). I did a bit of searching and discovered a few other suppliers:
Colmans | U.S. G.I. General Purpose Cargo Net - $14.95
Army Surplus Warehouse | Military Issue Cargo Net Securing - $14.95
Details:
Thanks man!!
  • Like
Reactions: Bud
It's been awhile since I posted anything about our cruiser. Life's been a ride, we moved for family, lost nearly everything in the wildfires that swept through in 2020 and we lost nearly everything. Our Cruiser survived by hauling our kids out, with niece driving them, while my wife and I stayed to fight the fires.
Cruiser sustained some internal damage from a very cracked intake that I only discovered recently. The motor ended up getting rebuilt because it was smoking, cylinders were ovaled. It ended up sitting a bunch for a bunch of reasons. Mice got into it and filled the headliner with a nest and a full bag of dog food. The Sunroof gears stripped out when we opened it because of the nest. To add insult to injury, the rain-drains were clogged and water spilled into the cab and caused mold. Lol
It was sitting silent for a few months so all of this took place without our knowledge. I've since stripped everything out and scrubbed and disinfected everything but it still has and odor. I'm going to do a few more things to rid the smell, I think the middle row seat had a nest in it so I'll be stripping it down and checking. Fingers crossed.
In the mean time I've got new gears for the transfer case, a long range fuel tank to go in and bigger tires with my long awaited steel wheel to install.
I put a Mean Green Alternator and New OE Power Steering Pump in because they both failed at the same time, and in the process I did my best to update the power supply lines and distribution.
I made a boring video of the most recent upgrades under the hood, including new modifications to the on board air system.
Have a look if you are curious.
Cheers!
Here are a few pics from adventures we've had over the last couple months.
as for the ‘funkiness’ or smell.. visit your local pest control place and pick up one of those desiccant bags. They work wonders!!! We had a terrible smell in our garage after hurricane Beryl beat us up, and we used that in combo with something that utilized a few drops of solution that you place on cotton balls, and put in a cup (rat-be-gone, funk-be-gone, or something-begone…i think it was called??)
wonderful photos, by the way…. kids dig Land Cruisers.
...wonderful photos, by the way…. kids dig Land Cruisers.
LOL, it ticks my wife off so bad that my son ALWAYS wants to ride home with me in the 100 rather than with her in the 2013 Ford Fusion. I have to keep telling her, "It's the truck sweetie, that's all it is..."
Thank you for the suggestions! I used a Thyme oil we use in the remediation industry for mold. It worked quite well but i need to do it again. I'll check this stuff out that you recommend.
That's great! Not ticking your wife off but that your son appreciates the rig. Well done to us dads!
These were supposed to upload but didnt.
I’ve seen this before:
daughter just assumes this will be hers one day. she doesn’t mind turning a wrench on it, when needed.
yeah, my nephew demands that i pick him up in the LC.. i sense a future ‘Cruiser owner.
This is fantastic! Oh what a feeling! TOYOTA!
