100 Series Land Cruiser stalling/losing power
Wyoming MI
2004 Toyota Land Cruiser, 400,000 miles
Won't start, open hood, close hood, starts.
Losing power when accelerating, power then comes back.
Losing power when driving on the expressway, cruise or no cruise.
Cruise set at 75, 70, 65, 45 doesn't matter, lose power, rpm's slowly drop, truck slows at a rate quicker than just shifting to neutral but slower than braking.
Happens mostly when under power, like climbing a hill, passing or merging.
Mash throttle to floor, no response.
Sudden return of power.
With window down and sudden return of power, exhaust smells very rich and raw.
I've researched the living hell out of this, it got so bad my truck was almost not drivable. Which sucked because it is my office.
Everyone else with this problem has replaced the fuel pump, throttle body, throttle pedal, plugs, wires, vacuum leaks, O2 sensors...all to no resolution that they ever posted.
I have found the culprit, replaced it, driven 1,000 miles and not had the issue since.
FUEL PUMP RELAY!!!
It was so bad my truck wouldn't start. Unless I tapped on the fuel pump relay while the engine was cranking over. Then it'd fire right up.
Went to O'Reilly's and bought a new relay for $16 (my cost) and BAM!!! problem solved.
Losing power was because the relay would cut power to the fuel pump, with no fuel the engine quits BUT because the transmission is still in gear it was spinning the engine over, the extra resistance of rotating the engine with the transmission was slowing the truck at an increased rate, faster than just shifting to neutral, slower than using the brakes. Engine braking would be the definition of this.
Relay comes back to life, fuel pump comes to life, because the engine is spinning the spark plugs are still sparking, sudden dump of fuel, engine comes back to life.
Because of the fuel dump not all fuel was burned, hence the "flooding" smell of the exhaust.
The longer the engine ran the worse/more frequent it got. I was on a 1200 road trip, started off no issues, then 10hrs in it was so bad I had to pull to the side of the expressway.
I never turn my truck off when road tripping. I drive straight through, engine running the whole way, even on a 24hr trip. Even while getting fuel, food, nap, etc.
I'm trying to use as many key words as possible for anyone who Googles this problem.
I have extra fuel pump relays in my glovebox now. The first time to have to slam my hood to get my truck to start I'm swapping the relay.
I hope this helps anyone and everyone.
This was the telltale. If it’s affected by movement/vibration, it’s almost always an electrical contact point. Glad you got it sorted out.
Thank you very much for sharing with the mud tribe!
man that was a rollercoaster. Did you solve this while you were in the middle of creating the thread??
Congrats on getting it figured out.
No. I solved it, drove for a week (~1,000 miles). Issue gone. Put old relay back, issue came back.
Before my trip I searched and searched to no avail. Then I figured it out after I was back at work.
The problem was figuring out what was moving and loosing contact. It always happened at about the same rpm/throttle position. So it felt like a dead spot in the throttle.
Not a fuel relay problem, but I just swapped out my clutch relay and the AC has kicked back on… hopefully for good. I am wondering if there Is there a way to determine a relay’s condition before it’s too late? Or should I just go ahead and start replacing as preventative maintenance?
