Cowl Seam and water intrusion
Discussion in '40- & 55-Series Tech' started by AutaviaFJ40, Jun 13, 2018 at 11:36 AM.
  1. AutaviaFJ40
    AutaviaFJ40
    118
    Media:
    29
    Albums:
    3
    171
    Apr 21, 2018
    Louisiana
    My cowl seam was caulked and painted with the vehicle in its previous life. It looks great, but now has some tiny cracks in the seams. Im getting water leaking into the front drivers footwell, which is dripping onto the fuse block and my front speaker.
    I believe the source is this seam...what is the best solution for tackling this short of completely removing the old caulking and repainting?
  2. tls3601
    tls3601
    3,511
    1,518
    Aug 18, 2013
    Prescott Valley, AZ
    Find matching touch up paint and use 3M Urethane Seam sealer, works excellent, just did on mine. It was a job I had been putting off. Find out how it works at next bath
    GA Architect likes this.
  3. AutaviaFJ40
    AutaviaFJ40
    118
    Media:
    29
    Albums:
    3
    171
    Apr 21, 2018
    Louisiana
    Put it right on top of existing seam?
    I was thinking about using this. thoughts?
  4. tls3601
    tls3601
    3,511
    1,518
    Aug 18, 2013
    Prescott Valley, AZ
    I scraped/removed what I could of the old, cleaned paint for any residue, used blue painters tape for margins. Waited to cure then painted touch-up style
    65swb45, GA Architect and AutaviaFJ40 like this.
  5. tls3601
    tls3601
    3,511
    1,518
    Aug 18, 2013
    Prescott Valley, AZ
    Have not used the fast and firm
  6. AutaviaFJ40
    AutaviaFJ40
    118
    Media:
    29
    Albums:
    3
    171
    Apr 21, 2018
    Louisiana
    Thanks, this is very helpful...didnt think about taping it off.
    Did you brush the touchup paint on?
  7. John McVicker
    John McVicker SILVER Star
    2,272
    596
    Jul 11, 2005
    Big Pine, CA
    Check your cowl drain tubes for leaks before doing any painting.
    Yes, your leak could be originating from the seams but it could also be from bad drain tubes. I sealed my seams up and it still leaked...it was the drain tubes.
  8. AutaviaFJ40
    AutaviaFJ40
    118
    Media:
    29
    Albums:
    3
    171
    Apr 21, 2018
    Louisiana
    Thanks, but mine is an 81...no drain tubes.
    John McVicker likes this.
  9. AutaviaFJ40
    AutaviaFJ40
    118
    Media:
    29
    Albums:
    3
    171
    Apr 21, 2018
    Louisiana
    I put a temp silicon sealer on the joint to water test it. If this stops the leak, I’m going to follow @tls3601 advise and reseal and paint
  10. 82FJ40EVV
    82FJ40EVV
    27
    23
    Jul 12, 2015
    Rockford, MN
    Silicon really messes with new paint..... don't take any shortcuts when cleaning it up / preparing for new paint.
    AutaviaFJ40 likes this.
  11. cult45
    cult45
    3,252
    1,323
    Nov 30, 2011
    Harbour City, the New Southern Wales
    Clear silicone is what I used, blended right in.
  12. AutaviaFJ40
    AutaviaFJ40
    118
    Media:
    29
    Albums:
    3
    171
    Apr 21, 2018
    Louisiana
    I was actually pleasantly surprised how easy this was to apply and how nicely it flowed into the cracks...but I wonder how long it will last?
    I selected it because I assumed it would be easy to remove in one piece...but I may just see how long it lasts first. Assuming this solves the problem...water test this afternoon will tell more.
  13. cult45
    cult45
    3,252
    1,323
    Nov 30, 2011
    If it's silicone then it will last. I recaulked my cowl seam over two years ago. Hasn't moved or leaked.
  14. AutaviaFJ40
    AutaviaFJ40
    118
    Media:
    29
    Albums:
    3
    171
    Apr 21, 2018
    Louisiana
    What I used is just a standard window/door exterior Silicone caulk...its not an automotive seam sealer. Is that what you used?
  15. cult45
    cult45
    3,252
    1,323
    Nov 30, 2011
    Yeah just the clear stuff you'd use in your bathroom.
  16. tls3601
    tls3601
    3,511
    1,518
    Aug 18, 2013
    Prescott Valley, AZ
    @AutaviaFJ40 yes good old artists style brush. Will do a second coat next time I am up North where the 40 is
  17. middlecalf
    middlecalf SILVER Star
    847
    285
    Jul 20, 2004
    Sweet, Idaho
    Years ago there used to be a silicone that would flow, great for things like this where the sealant needs to flow into all of those deep and dark crevices. Anyone know if this is still available?
  18. AutaviaFJ40
    AutaviaFJ40
    118
    Media:
    29
    Albums:
    3
    171
    Apr 21, 2018
    Louisiana
    Part 2
    The seam isn't the issue...its this mess
  19. AutaviaFJ40
    AutaviaFJ40
    118
    Media:
    29
    Albums:
    3
    171
    Apr 21, 2018
    Louisiana
    I cleaned it all out...I need to prep and prime the bare metal spots before re sealing it.
    Dynatron Seam Sealer #550 or 3M Fast'n Firm Seam Sealer 08505?
  20. S4Cruiser
    S4Cruiser SILVER Star
    3,408
    2,815
    Mar 15, 2006
    Durham, NC
    I'm a big fan of the Lord Fusor brands. Honestly though, most anything should work fine.
