- Joined
- Feb 14, 2009
- Messages
- 43
On my US 1997 LX450, the FPR signal from the ECU (open collector, to pull down and activate the coil on the fuel pump relay) is always pulled low, which causes the fuel pump to always be in low speed mode (~ 9V, powered through the fuel pump resistor). This makes the car always noticeably lean, especially with the supercharger. If I force the fuel pump into high speed mode (jumper to that leg on fuel pump relay or bypass the fuel pump resistor, full voltage to the pump) everything feels like it should be.
The FPR signal looks more like a short, at all times. I’d expect to at least see at least something like a 0.6V junction voltage from the open collector on a DMM in diode mode, but just looks like a short. I think I’ve isolated it to the ECU itself, not any short in the wiring leading to the relay pulling it to ground.
I couldn’t figure out exactly when the switch from low to high speed should happen from the FSM, but its diagnostics say I should see it after 60 seconds “while racing the engine.” I’ve driven it around and had this thing wide open to red-line on the road and never saw the FPR signal change or fuel pump voltage go above 9V (low speed mode).
Can someone tell me for sure when I should be seeing the relay change from low to high speed mode? Or what kind of readings (e.g. diode/junction voltage) I should see at the ECU on that pin when everything is disconnected? I’m reluctant to just spend the money for a new ECU if I could just have the wrong expectations.
Additional pertinent info: the fuel pump relay was swapped out because the old one was so rusted inside it was rattling, and was frozen in its normal position (high speed mode). It had probably been that way for a long time based on how thoroughly nasty the insides were. But there was enough debris rattling around inside that it’s possible that the coil was shorted out at some point (though found as open circuit), maybe explaining why the open collector output for FPR could have been fried, if that’s really the case.
Any info greatly appreciated!
