Which is why I haven't.How old is it? Return it for an exchange, my guess, will have the same performance result.
Just replaced a 3 year old Koyo 1918 with a TYC 1918. I anticipate pulling some heavy loads this summer and I had a chance to swap in the TYC for some comparisons. Koyo is clean and well maintained, so it should be performing well for what it is. The TYC has a slightly deeper core and the vertical tubes are noticeably longer, so there re obvious physical reasons that it MAY perform better that the Koyo. Thursday-Friday should be 110+ so good resting weather.
FYI - UPDATE. Many thanks to @brianh699 for getting that radiator to me. Not sure whats special about mine but the damage in his rad that he passed on to me just happens to have been damaged in the perfect way to allow it to fit without modification. I ordered a KOYO and an APDI that didn't fit because the 2 front holes were 1/4 inch to wide center to center. The bent one fit perfectly (30 inches 1/4 center to center). Weird. Anyway. here are some pictures and video of the results
As you can see there is something funky on the inlet side. All the paint had be heated away. Yes its behind the trans cooler but there is certainly something more than a little extra heat. Methinks my CSF had a block there, despite a flush. Factory damage? Who knows.
CSF exactly 30 and 1/4 center to center. Which fits perfectly in my 97
damaged TYC...30 1/4 inches center to center. Interdasting.
Anyway, it worked. Hottest temps now are 194 full high hot (going up a canyon with AC on in 95 degree heat. I did the same run with my CSF and it got to well over 226 and climbing.
And for fun, here is me getting it done.
Update time for me too.
Having been subjected to internet bullying and online social media peer pressure, I have caved and changed out my perfectly good
underwradiator for a new TYC 1918.
To make a long story short - I am surprised, amazed even, no... DOWNRIGHT STUNNEDat the difference.
193-195F now.
This is 2 good, clean working radiators. Direct A/B comparison. ZERO other changes. Days apart.
Radiator #1:
CSF 2517 metal tank, brass/copper 3 row. 2 years old and clean. Verified to flow water very well.
Beeline Hwy road trip to Shea Blvd, 5:30PM, 108F, 70mph steady.
Coolant temp generally 213-216F, peaking at 222 at Shea.
Coolant pressure 12-15.5psi, cycling up and down.
Overflow tank up 2 inches.
Radiator #2:
TYC 1918 plastic tank, aluminum 2 row. New.
Beeline Hwy road trip to Shea Blvd, 5:00PM, 111F, 70mph steady.
Coolant temp generally 193F, peaking at 195 at Shea.
Coolant pressure 11-12psi, steady.
Overflow tank - ZERO inches, because it hasn't exceeded the cap pressure limit.
That's 27 degrees cooler!
And there's more to it than just heat shedding ability.
The coolant system pressure behavior is very much different.
From a cold start (well cold for here), 1/2 mile from home:
The CSF would be at 155F and 15.5psi, already spilling into the overflow tank.
The TYC would also be at 155F, but only 6psi.
That part of it has nothing to do with heat exchanger performance - the thermostat isn't even open yet, and no water is being cooled.
BUT... that radiator is doing something.
The only thing I can think of is that the brass radiator is stiff and rigid, non-compliant, so that coolant expansion has to go out of the system.
Whereas, the wide flat aluminum tubes, plus the plastic tanks, can swell and increase volume some under pressure, so the pressure doesn't increase as fast.
It's a theory.
So anyways, emboldened by that casual defeat of the Shea Blvd "hill", I continued the attack on Mt. Ord.
No problems at all.
Pushed hard and held 65MPH on the hills in 2nd gear at 4400 RPM.
Temperature would climb slowly to 202F at the top of Sunflower and Mt. Ord hills.
Coolant pressure did go up and hit 15psi a couple of times due to the high pump RPMs.
Overflow tank up 1 inch at the top.
On the way back, there was a bad accident at Ft. McDowell Rd, so sitting in traffic for 30 minutes with A/C blasting - temp crept up to 209F, but quickly dropped to 193 when we got moving.
I would expect an aluminum radiator to perform better (marginally) but not 27° F. better. Something is wrong with the 2517 you have.
That's all we're saying: Some of us apparently received f*cked up CSF's.
thinking on it I think its just that the entire rad was hot and the extra heat from the trans cooler would have done that discoloration.Which would immediately start to cool. Not get hotter.
Grill removal can be done with the bumper in place.
I don't recall that grill removal is necessary to replace the radiator which was the original question/assumption. That said, removal/installation of an ARB was not that difficult in my case even with a Warn 12K winch. Work smarter not harder.
