Downey
Read alot of threads, answered alot of questions, but never initiated a thread, so heres hoping I'm doing this correctly?
There are five factors involved in getting a Chevota to run cool enough:
(a) Minor Importance; you can not be using a late model "smog device" thermostat, they generally will not let the engine run coller than 220 degrees. Get a 160 or 180 degree thermostat.
(b) Minor Importance; you must use a radiator with enough GPH (gallons per hour) rating to cool a V8. These are generally a 4 core copper or 2 core aluminum
(c) Minor Importance; you must have a good radiator position. On FJ40 Landcruisers the stock radiator position is generally too high (not centered directly in front of fan) and too far forward (requiring a fan shroud, that most people use improperly).
(d) Major Importance; if your radiator is more than about 1" in front of the fan, you will probably need a fan shroud. It has been proven that engines do run cooler when there is a fan shroud, BUT it has also been proven that the engine runs the coolest when Zero Percent of the fan blade is inside the fan shroud. Your fan shroud should end at the front edge of the fan blade.
(e) Major Importance; flex fans don't work at all!!!! Problem with electric fans is that by the time you get one that has enough CFM, it is probably too big to fit inside your engine compartment. Chevota owners typically use less than 2500 CFM fans when they should have used 3500 CFM minimum. What works the best is the mother of all AIR CONDITIONING FAN BLADES. These are rigid steel, 7 or 8 bladed, 2" thick, chain saw massacre Surburban fan blades.
