- Thread starter
- #21
Mild build: I wanna enjoy it so keeping the downtime to a minimum will be a priority.
I'll be prioritizing the camper side. First thing is to upgrade the dual battery setup. I have a 12V 1500w GO power puresine wave inverter from the first version of the Zombie Trailer's electrical system as well as 2 12V 200Ah AGM batteries that'll go in as well. Rewire the entire camper side for 110v. 600-900w of solar panels should fit on the roof. The camper has a propane refrigerator/freezer that I'll probably replace with a compressor based refrigerator/freezer. Stove may be upgraded to a induction cooktop like the one I have in the Zombie Trailer. The propane heaters analog temperature controller will be switched out for a digital one. Since the heater is a 10000btu unit I'll probably install a 10000btu window AC unit as well.
The cabover bed will be re foamed and new sheets added. Same with the dinette cushions.
Later in the summer after I finish the 2FE build for my FJ40 I'll pull the 20r and more than likely put in the spare 7MGTE engine I have for my '87 Supra Turbo (May source a non turbo 7MGE instead. Shoehorning the intercooler and piping may be too much a pain.) I have a W58 and R154 transmission to upgrade the 4 speed L43. The W58 appears to be the easier swap.
Since the rear is a 8" 3rd member the LSD from my Supra should fit for improved traction. Yup got a spare of that too. I'll be on the hunt for a 1ton ff dually from the later Toyota motorhomes. Although the axle is pre recall for peace of mind I'll upgrade.
That's the tentative plan. It'll keep all my vehicles inline 6 and keep the number of different spare engines/transmissions to a minimum.
Crazy? Oh yes. If anyone sees problems or has better suggestions let me know.
Oh and does anybody know of brake upgrades for a '78 Toyota hilux?
