Cone Washers FJ40 truck
i guess i depends on what truck your talking about?
CruisinGA said:
Just fine.
Not a bad idea to replace all the hardware, especially if running large tires, P/S etc, but nothing wrong with reusing.
Definately going to replace the Studs I would think they take all the stress.
I don't see anything magic about the nuts, am I missing something? I was just going to pick up some from the Hardware store.
you can get these studs from marlin here i like them for the idea of the the torx heads...
I would be carefull about were I got the studs, You need the right grade.
I would only buy Toyota or upgrade hardware from a cruiser vendor...
Unless you really know your metal grades and are certain what you are getting from the store...
Loose and broken nuts/washers/studs can cause you a world of hurt.
Poser said:
If you are going to be replacing them, and ever forsee a hy-steer upgrade, I would go this route...
http://www.frontrangeoffroadfab.com/knuckle_studs.htm
Stock them.
Brian is a great guy!
Good luck!
-Steve
I have to install the All Pro HySteer kit after I swap to Truck Knuckles. What makes the frontrange stuff worth $89 a set?
