Colonel Mustard refresh and update
New
I debated on what fairlead to use, the old roller type or new design, thoughts?
I don't know what you mean by "new design", but for steel cable definitely use a roller fairlead. I have a old steel hawse fairlead in my junk pile and it's all grooved from steel cable. Nowadays, most of them are aluminum.
Ok cleaning time
Paint first
The truck has mostly original paint. So I soaked it with Mcguires #7. The key I found is to let it sit overnight and remove with a Terry cloth. I did this process several times on the exterior as well as areas of the interior. I was please with the results.
Ok cleaning time
Paint first
You could keep that divit in the hood from getting any bigger by installing a roof drip channel cushion, part number 63118-90300 still available from Toyota for 3 bucks.
Mine as well install a set of new Koito headlights while I’m doing all the front end upgrades. What a cost effective and major improvement , I highly recommend. Lots of threads on this one.
Next up, interior redo, or is it suspension time?
Stay tuned
Continuing...
PO did lift and shackles w/o any castor adjustment. Truck sort of zigged and zagged.
Installed 4 degree wedges and had to lengthen u bolts so had some made
Looking great...keep up the good work.
