Got up this morning and my engine wouldn't start. cranking beautifully, but just didn't want to start. After checking to make sure no fuel lines nor any of the distributor connections were lose, I got around to the ECU. Connecting the SST, er wire, I discovered the sole 12 code but no other.
Cleaned the connectors but no luck.
Is this a symptom of the problem? Would the engine not start if NE and G signals were missing from the ECU or would it just work poorly?
Any ideas before I take the distributor apart? I can make sure sparks are igniting... is there a remote start switch for the 3FE, which I can use from the engine bay?
thx
thx
