I'm glad to see this thread start. It is getting me motivated.
I started doing this a couple of years ago on my second Cruiser. Going to try and get it finished this summer.
One recommendation I have is to weld it solid before you cut.
That brings me to my question. What is the distance between the drivers and pass. side of the rear opening for the ambulance doors.
Looking Good Dan.
Thanks,
Looking Good Dan.
Thanks,
. I should have reviewed the install instruction before I started. My thoughts were
if I welded the new qrt. panel to the bend of the top channel, I would just replace the rocker panel with a thicker guage metal and raise it up an inch. So, I got on the CCOT website realized I would probably create more issues down the road, example . . . fenders not lining up with the raised step mount. The CCOT install requires you to cut 1" down from the top bend, basically cutting right down the center of the top channel spot welds. I removed the majority of the metal from the original quarter panel, and put the new panel in place to line every thing up before I made my final cuts.
