Builds BurntToast's FJ62 Build "Hoss" (21 Viewers)
6L80e Tax 🤷‍♂️
Probably wasting a lot of time on OEM stuff, but I like the classic look of the filter box. Going to cut out the small input and weld in a larger one. My intuition says the filter is fine.
thanks to @Dubs2017 for reminding me to do this. I was ignoring it
very nice! Gotta bump this up on my list. Thanks for posting pics.
Wasn’t terribly hard, I used a paper tube, cut it to fit. Then transferred that to the pipe. Lots of test fitting and grinding. Worst part was welding the .062” new tube to the .039 or less stock Toyota stuff. Blew through a couple times on my lowest setting MIG. Wish I had a TIG welder for this stuff
I love seeing a modern motor under the hood but it's also a bit jarring. I love to see someone devoted to the little things to tie them together.
Speedhut Gauges have arrived, but unfortunately they sent me the GPS speedo. I talked with Speedhut and they have no issue working the GM E38 VSS signal into their VSS gauges, so I would prefer to hardwire. Mosley hopefully can negotiate a swapout.
Found a nice tap for oil pressure gauge. Direct thread into the engine with 1/8" NPT taps for the speedhut gauges.
Drop in cig lighter replacement. Has a USB-C charge and connection for wired carplay.
How long did they take to arrive since ordering?
