Very nice
. Glad to see it up and on the road.
This think looks beautiful! I like your tagline, too. I’d like to think that this stands for original equipment modified—they are more fun this wayThanks Dennis... It completely changed the look.
The 5.7 is a beast of an engine in something this light.... And it sounds great too.
OMG. I want! Awesome idea and great execution!Trying to get the last couple small things done before my last batch of painting. I've been thinking about what to do with the cowl vent.
On my last 40, I just used a block off plate so I wouldn't have to worry about the drain tubes. On this build, I was going to use the OEM vent, but there isn't really a ram air effect like the kick vents. Also, I'm not crazy about the open slats that let pine needles and other junk in.
I decided to make my own that is a block off plate when its closed, and has a ram air effect when its open.
Starting out -
Adding flat bar stock as reinforcement -
Building the rest of the hinge mechanism -
Cross brace installed and test fitting -
Attaching the lid and lining everything up -
Back in the closed position -
Tomorrow, I'll hook up the push/pull for the FRESH PULL, which will pop the vent open. I'm really happy with how it came out!
Well, still having a blast with URJ45. I did a couple small modifications in the past week.
First one was a 1" coil spring spacer lift. I wanted a bit more up travel before hitting my bump stops, but didn't want the firmness of an aftermarket lift spring, so I put on some 1" Ironman 4x4 spacers. They fit and did exactly what I wanted. Until now, I haven't ran the front or rear swaybar. Being that its a bit higher now, I installed the OEM rear 80 series sway bar and the handling and ride is fantastic.
I was also not super enthused about the sound of the exhaust with the cutout open. It was definitely louder, but not a good loud. It sounded more like a high school kid running open headers on a Camaro.
I put in a couple 45 degree bends as well as a 12" resonator off of the cutout. I can't believe how much it improved the quality of the sound. The rasp is completely gone, and the rumble I want is there. It sounds similar to the TRD exhaust on my Tundra, just a bit louder.
Kinda hard to hear on a phone or computer speakers, but anything with a subfoofer and you'll be able to hear the lower pitch -
Thanks Mike!Sounds great!
Thank you! I'm pretty happy with it!Beautiful build, perfect blend of modern technology and old school classic Looks !
You hit it OUT OF THE PARK !!
Thanks! I was lucky enough to be able to build my own dream truck too!You built my dream truck
37x13.5'sI may have missed it and can not seem to find it.
What size tires?
FJ Cruiser steel wheels?
Gear ratio in axles?
Thanks
Soon!I can't wait to see it in person.
