- Thread starter
- #401
Small addition to Bonnie. Wife and daughter did the crane thing at Destin Arcade, where you win something every time. Somehow we have 30 ducks and one single pig. Well only one mattered.
It’s always interesting, battery died while waiting for car wash to open as I shut her off to wait.
AlI love the homeless guy look. I know that decision and I care less some days…so I occasionally run in and just let them deal with it. You carry a different position in your community. What do you do when some recognizes you and then says “. Hey Bill, I saw doc yesterday…he’s looks like …..”![]()
Thanks, connections should be first and least costly look.Last ranch working holiday had me hitting the battery cable on dad’s Mini Ex with a rock to get it to start, he had cleaned everything and tightened it all up in the spring to no avail…my brother took a look and found fresh corrosion behind the lug where it bolted onto the battery clamp, a spot not previously opened up. Exact same symptom.
Keep looking at cable connections is my guess, good luck!
To me it sounds like the ignition switch.If this doesn’t work possibly ignition issue?
Knew a girl wit SpurrsIn the series YELLOWSTONE…there is a scene where Rip walks in to pick up a pair of hand made spurs and meets the same guy !!
Exciting! H55 would have been my dream setup instead of that Ranger. Don't give that TBI SBC away too cheaply. It only had 20K+/- on a complete professional rebuild when you drove off. Anxious to see how it all turns out.Looks like Bonnie going to get upgraded.
Crawled under her short while ago noted multiple leaks starting from tranny and overdrive. So reached out to @Pigeaten. I was very impressed with Steve when he stopped by for the night. Apparently @RUSH55 was a fan also when he drove Steve from what Don said.
Just got off phone with Steve from Northwest design. Looking at what cost difference between new GM motor versus used depending on what can be found. Use rebuilt H55 I have here in shop. Install AC and updated dash gauges. He said he felt he could start on her end of October.
I know that the SBC with TBI and ranger OD with 4 speed treated Jim and Bonnie well through the years but I just feel it’s best for Kim and I to happily utilize Bonnie like we want we need to modernize her.
Those papers are just his EPA logs!Last week I took off work and hauled the spare tank an hour away to old fashion radiator shop.
Owner (old veteran whose health has seen better days) sitting in his office in the old gas station. Don’t think his area had been cleaned up with papers in years and this just added to my excitement.
We talked for probably half hour about tanks he has saved over the years. I’m quite certain he may use techniques not allowed anymore.
Once that’s done it’s swap time again. My only concern is while walking out he said “see ya between tomorrow and Christmas!”
Either way I’m pretty excited I found the right guy to help.
