Bolt on turbo kit
Yup. That’s it!
According to Amazon, when I select a Subaru oil cap it says it doesn’t fit the ‘96 Landcruiser.
Someone with a 3D printer needs to make an adapter. Anyone with a 3D printer?
I actually have a feeling it might be the same for the earlier suby. But yeah, I hear ya ;)
I could perform a highly accurate analysis for you regarding the interchangablility of an earlier Subie oil cap and an 80 Series. But your going to need to modivate me to get off my arse and walk out to the driveway with two sets of vehicle keys.
How about cash? I’ll bet you $20 the sub’s oil cap is actually larger than the 80 ;)
You'd be $20 up, Subaru oil cap at least from 99 (earliest I have here right now) up to 2019 is larger than the 1fz cap at least based off the EJ and FA engine's anyway
Oh noes! 😳
And since it’s Dylan’s truck I will be bringing:
* bottle of Scotch
* tow strap
* bars stop leak
* AAA card
* battery jumper
* 200# of tools
* 50cc Yamaha
* hand sanitizer
* condoms
And guess you gonna use mobile 1 for lube?
Update time:
* Hit 7 psi this morning
* Surprises when going maybe 10mph and then floor it
* It instantly downshifted and I hit 7psi in no time
* It definitely moved
* In a flash saw 10 something on the AFR and then saw lots of low 11s
* still cant believe the rush of air through the exhaust system. It is moving soooooo much air
* no CEL
* will do 30 mile trip this afternoon
So you changed the Tial springs to increase boost?
The boost rabbit hole is already starting! 😂
What are safe AFR numbers for our engine & turbo kit?
I’d like to have some guages to see what’s happening with the turbo. But I have no idea what’s important to monitor (AFR, boost, EGT, ect...), & what numbers on those guages should be.
Are you going to recommend a set of gauges, provide a kit, suggestions on what’s compatible, ect?
