I'm sure there's plenty out there running fine it was merely a suggestion/thought on my end nothing more.
No worries
What does your butt-dynometer estimate?![]()
It's entirely possible I'm not in position of having Mr. T's design reasoning's.
Agreed there's plenty of products out there to assist with thermal's when it comes to underhood radiant temps and such, as I stated it wasn't me questioning whether or not an aluminum housing would function or not I know it will I probably tune 15 cars a weeks with aluminum MAF housings incorporating IAT I was merely suggesting that a properly designed and constructed ABS/Polymer design might afford benefits.
Some notes about a quick run this morning...
* 25 miles put on so far
* two WOT runs and the system hits just shy of 6psi
* no boost controller and blue wastegate spring
* climbed a decent hill going 70mph and it stayed at about 3psi the whole way up the hill and never downshifted
* when you get on the boost there is so much air being moved and pushed out the exhaust. You can definitely hear the air flying through the muffler and tailpipe.
* adjustments made to the intake piping and it is a little farther from the turbo now and isn't nearly as warm
* The front intake portion no longer touches the hood insulation
* The check engine light is still off
* Everything is working as it should so far
Forgot to add but this is all at 7000' and higher.
6-7 panties and at least 2 boxer briefs![]()
50 miles in. Nothing smoking, nothing on fire, nothing leaking (except for everything else on the truck)
No CEL after 50 miles and 8 cycles!!
When I first read your performance, I thought big deal at lower elevation, then when you said 7000' that was more interesting.
Little off subject, but I had never driven our/an 80 at lower elevations. Lowest has been Denver, Grand Junction All my experience has been around home at 6000+. That changed however, just went down to Vegas from NW Colorado, back around via Hoover Dam, I40 and Grand Canyon and back up through Moab. 80 was pretty peppy on the interstate at lower elevations, ran about 84MPH most the way down 70 and 15. Had good passing power and such, shifted down, revved up above 3800 it hauled ass. Cruising seemed to want to stay in OD more at higher RPM of 80+MPH. Got back up into Colorado, cruising at 60-65 on the two lane roads and it starts hunting and bouncing back and forth between 3rd and OD with the slightest bit of throttle manipulation. Tolerable most the time, but very annoying when pulling our travel trailer. When you just need the extra little bump of speed or gas for the wind it shifts down, then, up, then down. Seemed the higher speeds kept it in a better power band.
Can't say I have the fun money for this kit or the stomach for the premium fuel, but it sure would be nice in the mountains, especially with the camper.
I knew your were cheating!!50 miles in. Nothing smoking, nothing on fire, nothing leaking (except for everything else on the truck)
No CEL after 50 miles and 8 cyclinders!!
I knew your were cheating!!![]()
Question.
Air/oil separator, would you recommend for this setup?
GrimmSpeed sells a nifty one that screws into the oil cap. Self drains back into engine. Designed for Subaru WRX, not sure if caps are interchangeable.
Or a typical baffled oil catch can?
