Bolt on turbo kit (18 Viewers)
second mortgage is always an option :hillbilly:
All predictions show a conservative 40% increase from stock. So if stock is around 135awhp and 185ft/lbs, you should see around 190awhp and somewhere around 260+ft/lbs.
Let’s talk about SC and wheeling generally. One thing I love about online six engines is the power delivery off-road is never punchy.
How does the SC affect crawling where there may be times you get up a bit in RPM due to tire spin or a need for a bit of throttle?
SC and wheeling = lots of heat
How about throttle response in terms of unwanted sudden boost? Like on a serious technical climb where control and predictability are key? Does that favor a SC or just NA?
One thing that makes me reluctant to do anything FI or even engine swap is that I perceive the stock NA torque curve as perfect for crawling. Even the 2UZ in my Sequoia is “jumpy” in comparison although that’s not a straight apples to apples comparison.
I had no problem with my SC doing technical. Still predictable simply didn't need as much skinny pedal-no unwanted boost/power at all.
Post updated to reflect an accurate list of people willing to buy.
Badass Turbo owners list
1. HDJdreams
2. ThomasMore66 - ?
3. SteelHunterFJ80
4. Heckraiser
5. DCGuillroy
6. Snow-globe
7. Bucketman
If there was a bolt on Turbo kit for ODBII 95+ cruisers using high quality US made parts, Borg Warner, Tial, etc. And the base kit was $3000. And an upgraded intercooler kit was available for another $1000.
How many people would be interested?
What questions or concerns would you have?
I know everyone wants more power and it is Mud so an engine swap should only cost $1000, but these are fairly realistic numbers, they are pretty steep considering the cost of entry into the 80 market is sometimes less than $4000, but to get high quality parts it would cost more than the CX racing junk.
Disclaimer, this is only an information gathering post, I personally am not in a position to put these kits together but I would certainly want to help make sure they are done right.
You may add my name to the list, yeeha!!
Having owned and wheel 80 series for the supercharger the supercharger did not change the way I wheeled at all. Even though I have not wheeled my turbocharged Land Cruiser I would expect the same from it mainly because nothing happens until you hit 2000 RPMs Plus
Just to add to what Phil is saying when the turbo spools up the power is not "jumpy"... mine is totally smooth no matter how technical.
I'm almost done putting together my own turbo "kit" list of items to purchase. No doubt I will forget some things and end up stretching this project out longer than planned, but need to get started in order to be completed by August due to a MOAB trip in September. I have read every page of this post and although I may have glazed over a few posts after the 4th hour that contain answers to my questions below, it looks pretty good overall.
I see it's been 10 months since the 1st post and people are not trying to rush you (and neither am I), but need to know before I go down my own path - what is the timeframe for putting this kit on the market? Are you still in the same initial price point of $3k? Finally, the $1k intercooler - was that A2A or W2A?
Thanks, Convoy
Thanks, Convoy
I think we all agreed water is better.
I think water to air is better at lower speeds. Air-to-air probably better at higher speeds. Mine is water to air and has been great...no detonation issues at all.
That's good. I was planning to go the W2A direction as well for max approach angle clearances.
There was never a timeframe in mind when this started. It was kind of a "when it all comes together" kind of thing. I have to come at this at a very different way than someone doing a one-off build. In fact for a one-off build that has already been accomplished with a Holset. But I needed this to be something that was production worthy, marketable and as bolt-on as possible. Very few has access to the kind of stuff me and a few others have access to. Now that being said, I have one thing that has slowed progress but I think I have that solved. Everything else is still being developed in the background. I also have other product projects I'm working on as a way to fill in the time gaps. Sometimes it feels like those progress better than the turbo does. Then I overcome a hurdle and then its all turbo and the other stuff gets no love. SO its a balancing act.
If I'm smart, I would wait until the temps get cooler and release this in the fall or even winter so that we can all enjoy the most benefit with ambient temps working in our favor. BUT...with what is going on in the background it looks like it could be mid-summer. I make ZERO promises on timing until I have ALL production pieces worked out and actually being produced. I've had some pretty hard lessons that I just cannot rely on fabricators and metal shops. I get burned every time.
No. That estimate was made before I got involved and before I was manufacturing all of the pieces necessary to make this a bolt on and before I was supplying all of the OEM bits to complete the install without having to run to the parts store. I DO know I don't want to surpass the price of the going rate for a SuperCharger which is currently $4400.
Right now the price is assumed, still need to work out the details but it will definitely be a W2A. That is as close to bolt on as possible.
http://swaintech.com/race-coatings/race-coating-descriptions/white-lightning-exhaust-coatings/
In another thread, I asked about ceramic coating heat insulating abilities. Looks like this product reduces ambient heat dissipation by 35-55%, cost for exhaust manifold ($200-ish), y-pipe ($80-ish)...
Curious about what peeps think about ceramic coating the j-pipes, turbo housing, any other parts to reduce underhood temps that I think will rise with this kit.
Discuss....
