2001LC
- Thread starter
- #61
I really can't wait to see you do rock chips & re-clear. I've gotten a little better after 30 day of working whitelady's paint. 50 chip on body & 50 in door jams (most under threshold trim). A few even looked ok, but for sure all I removed the rust & effectively protected against future rust issues.Thanks, it's part of my livelihood so hopefully I'm good at it hahaha. I've tried the synthetic clay bars before and I was pleasantly surprised. I usually use my usual claybar for the heavy nitty gritty and the synthetic pads for light duties. I have the Optimum Opti-Eraser and it works effectively, but $20 for it is a bit steep. You don't have to worry about dropping it on the ground and ruining it, but I guess I'm old-school at heart when it comes to paint prep.
In regards to wetsanding, just make sure you use the finest grit sandpaper possible 2000-2500 grit, and plenty of lube IE: soapy water. Cross-hatching patterns going in opposite directions. Just think of it as polishing on a steroidal level with a realllllly heavy cut compound!
When I worked for Jaguar and Land Rover, there were plenty of brand new vehicles with orange peel paint and other defects which customers would go crazy over... Those clear coats were super thin, luckily our trucks have been blessed with a more robust clear which may scratch relatively easy, but is easy to fix without destroying the paint job. In the end it's really just about maintenance and making sure to avoid bad cleaning habits which lead to scratches and other annoying crap. People sometimes call me crazy but I let my work speak for itself.
Come spring maybe I start a thread in the Paint and Body forum section of the site and show some of the things I do. I have to repair some rock chips in the front of my hood/filler panel below the grille (yes, it can be repainted but it's so small it'll be good to document) plus the clear coat is peeling off my rear passenger side door handle and yes, it should be repainted properly but I'd give it a go and wetsand and reclear myself first.
Keep us updated, we want to see the restoration in progress!!!
I've been thinking I'd like to start clear wrapping leading surfaces once paint is perfected on some of these high mileage rigs. What would it cost or have done or DIY?How many of you guys are running full vehicle PPF wraps? I figured with all the offroading you guys do around here, going through brush, etc. It would be super beneficial in preserving the OEM paint and not having it scratch to hell.
I work for a premium detail shop in the Chicago area and it seems like the trend is steadily picking up with more and more people wrapping full cars as soon as they get them brand new. The standard package is still either a full front or partial front, but full wraps are pretty common for us these days. Most of the high-end PPF films are self healing as well so you don't have to worry about crazy amounts of swirls marks, etc.
XPEL has a pre-cut kit for the LX and I believe the 100 LC as well which is what we used on mine, didn't do the full vehicle since it doesn't go offroad at all.
On a side note, if nothing else, I would order their pre cut headlight kits and install them after polishing and correcting your lights (to those with the later model plastic lenses). Toyota is notorious with using thin UV clear on the lenses that starts to dull and yellow as the vehicle ages because the barrier breaks down over time and the plastic is exposed to oxygen and water causing it to haze up and yellow. Applying the PPF right after sanding and polishing to a mirror finish will ensure that the yellowing never comes back (for at least 5 years or so until the film starts to go). Way cheaper than taking off your lights and having a shop re-clearcoat them, plus there's the amazing chip/pitting protection naturally offered by the film.
I still remember one of our old clients coming back last year with a 2007 IS350. We put PPF on his lights when he got the car brand new almost 10 years ago. The film was old school back then (either Avery or the old 3M I believe that sucks in quality compared to today's products). We replaced the old faded film for him with new Suntek PPF. After taking the old film off, the lenses looked BRAND NEW still. Not a single chip, zero pitting, zero yellowing. By now most people who have not protected their lights on the older IS models are probably buying new headlights at the dealer for thousands of dollars. Well worth the investment in the PPF imo.
