On tweaking your pump, you will want to grab a small notebook or an app for your phone and document your tweaks (EGT's/Boost/mileage/smoke). Just keep tweaking until you're happy.
That ball looks massive at that angle!
So what fuel line broke? A Cummins hard line off the IP or one of the Toyota ones?
The pyrometer is supposed to be installed in the exhaust manifold pre-turbo. That's where Dave, Mike and myself have the probes installed.
The reason why is so you can monitor the temperature of the air going into the turbo.
Anything over 1200 degrees F and you have to worry about damage to the turbo, keeping your EGT over that temp for too long can actually start melting the casting.
I try to keep it at 1000 when cruising, not my favorite number but it's better than 1200. Once the AC is installed and the knuckles are redone next week, I'm getting the timing adjusted. Hopefully that will lower it by a few hundreds. Not sure what else could be the cause.
Bigger Exhaust, better turbo, intercooler, timing will help but only a little bit. More timing means more heat in the motor though. Instead of going out the tailpipe so don't be surprised if your coolant temp gauge runs a little higher. Oil pressure will slightly drop and idle will become slightly inconsistent but fuel mileage will increase as well as quickness of turbo spool. What kind of motor are you going for?
Note: if your questioning my worthiness I have tuned 5 6bt's now the 3 standards are getting over 22 mpg and the autos are getting 18. I have built a VE pump from the ground up so I know those pumps very well. The 4bt is identical just 2 cylinders short.
