Builds Big Red Toy (15 Viewers)
Get that Champion 3 row that I put in
That's the stock size for a 3fe engine. I'm looking for something larger, that can hold more coolant.
I doubt think you'll find a larger radiator that will bolt in. There are plenty of aftermarket radiators out there, listed by core size, you just have to flip through the catalog.
@Hojack .
Let me know if you need better pics. Had to snap them quickly. I can't see any leaks from the head gasket
How much bigger if any is an 80 series rad compared to the 60? Mine cools my engine just fine but I'm not pulling near as much weight as Big Red.
You have two extra cylinders. You're not working your engine nearly as hard as Mike is in Big Red.
That is true. There's your fix Mike. Put in a 5.9
OEM T.Rad HJ61 radiator is still available in the US market.
See your dealer: 16400-68160 About $400 bones.
Or an HJ61 radiator. These don't have the automatic tranny cooling lines that are needed on US spec 62's. Toyota radiators also come with the radiator cap.
img_3108-jpg.1466216
Mike, is your radiator the stock 62 one or did you swap a new one in a while ago?
Some options:
Thanks Dave. I swapped a new one in a few years back, looks identical to the picture. It's a shame to replace it so soon.
If you go the Champion route they will accept the Toyota rad cap. I'm sure they have a bigger one than stock.
