pb4ugo
It's probably ok. I'm not sure you'll find other shims with smaller hole. The U bolts will help hold the spring pack together, but breaking center pins is not unheard of. IMO, the wedge is trying to be spit out. The other issue with smaller spring pins is the head of the pin is slightly smaller than they would be with a stk spring, so there will be more slop in relation to the axles spring perch hole. As I mentioned previously, I go about this a different way.
