- Joined
- Jul 20, 2004
- Threads
- 274
- Messages
- 23,204
- Location
- Chandler, AZ
- Website
- www.tontorecreationalliance.org
In the trade it is common knowledge that the colour of the fluid changes in relation to water content, a quick glance tells you whether you should get out the moisture content tester, of course we don't know if customers have had the turkey baster out, any doubt and we get the tester out. ...
Kinda,,, very dark fluid is almost always bad, but relatively clear fluid can have high moisture content. A new bottle, left open to the air will absorb moisture, can look brand new and have high moisture content.
... Unfortunately brakes systems do not exchange fluid during operation except when putting in new brake pads, i.e. when fluid gets pushed back up the lines into the master. So changing the reservoir contents may well help visually/psychologically but is of limited use, water being heavier than brake fluid it falls to the lowest point in the system..........i.e. the brake callipers, just where you don't need it.
But the fluid does circulate, not like a cooling system, but it does. When the pedal is pushed, the pistons drive fluid, when released it returns to the reservoir. Take a dirty system and change only the reservoir, with a short amount of driving it will be dirty again, do this several times and the whole system will be much cleaner.
One of the advantages of brake fluid is the moisture stays in suspension, evenly mixed with the fluid, doesn't separate. The reservoir is the only significant place where it's exposed to moisture, is where the moisture enters the system.
Changing the reservoir does have benefit, will reduce the moisture percentage. Don't count on it to replace the occasional full flush, but will help between flushes.
