Builds Benjamin’s 3D Prints Build (1 Viewer)
I'm looking to get rid of the butterfly.
Make 19 V1 Fog Light Mount (Rigid D2) (editing)
1. Overview of the Final Product
2 Introduction
The fin/teeth structures are designed to force air to flow through the heatsink. The fin/teeth structures are not necessary for D2 lights to work. But for 3d printed parts, it barely adds to the fabrication cost. D2 fog lights are recommended. The mount is designed to accommodate the wide light pattern (85 deg).
3 Installation
3 Purchase
$150/pair
Shipping $12.1 (USPS Priority)
Lead time is 3 weeks.
PM or email Ben3DBuild@gmail.com.
Would you say this is a big improvement over stock fogs? Hard to tell and I've had zero hands on look at any Rigid lights.
Hey Ben that fog light bracket looks great on the LC. Is there an upcoming option for the Lx? I believe the LX’s fog light slot is longer than the LC, possible to do a dual-dually bracket?
I didn’t not realize there was a difference. I’m in for a set of LX ones. I just drove through snow at night with the factory fogs and was decided on this upgrade
Just managed to finish up fitting these - Don't think I will see many other Amazons in the UK with these fitted :) Another great solution to fitting extras into the Land Cruisers
Now considering the Fog Lamp brackets........
I mailed out a mirrored version of the cupholder to the UK a few days back. I am really curious if that fits or not.
Removed my audio head unit this morning. Want to do something like this with scangauge and radio or something elese. This is only to show the idea.
Is there a way to connect iphone to the factory amp directly? Like a bluetooth receiver? I found these.
Amazon product ASIN B07FZ3G7SCAmazon product ASIN B078J3GTRK
We have installed a couple of these in Land cruisers, they have Tablet charging so we can mount up an iPad, then this takes the place of a traditional head unit and runs everything on the tablet. Works great for Maps, music, and everything else you want to run, plus you can take your Ipad with you and plan trips
Does this replace the factory amp or connects to it?
it connects right to it. it basically replaces your radio. so you have to get a couple of connectors for the wiring, but it's less invasive and uses the same setup.
Can anyone tell me where the two plastic pieces are supposed to go on Ben’s front cup holders?
These two plastic pieces
These pieces are not components of the cupholder hahaha. These are M24, which you can glue to fix the broken window switches.
