Hi all, those 'sparkies' amongst you please have a glance at the four diagrams below if you would. They relate to my dual battery setup. I have run diagram #1 for the last four and a half years I guess when I converted 24v starting to 12 volt, so I know it works with some minor irritations, poor lighting for the first couple of minutes until the VSR kicks in, obviously the aux battery also takes longer to come to full charge as it is the one that is exposed to the longest period of drain, so I am now in the process of refining everything, fitting the correct starter (as opposed to my custom 3.0 kw unit), reducing cable runs and generally tidying the whole affair up. The cables running from the battery and alternator presently run under the radiator being protected by the main cross member in the event of a shunt. I am now planning to run under the slam panel where the bonnet lock runs, this will provide a shorter run, but assume all fuses are where they are supposed to be.
A quick run down to offer some extra information which may or may not colour your thoughts. The aux battery is the one being pulled on by parasitic drain i.e. clock, alarm, and when camping fridge but this is minimal and only at night as there is a solar panel that covers the fridge draw during the day, the fusible links are still in use from there as well. The aux battery is now struggling to maintain it's voltage and to be fair has done it's job, and the real reason to consider replacing the pair in the very near future. The starter battery apart from the short period of time it is paralleled with the aux does see the parasitic draw until the VSR splits them, other than that, it is for the starter use only. I chose to keep the left battery for the starter to keep voltage drop down, and run the alternator to it for the same reason i.e. prioritise starting/charging to that supply.
I had been studying other ideas/diagrams for the refinement process, and one that caught my eye was the idea of NOT relying on the chassis for earth across the batteries as in diagram #2 i.e. run another negative cable to each negative battery terminal, if this is going to reduce voltage drop then connecting the alternator to the auxiliary battery should yield less voltage drop to the auxiliary hopefully extending it's working life, and still offer the minimum voltage drop to the starter battery, I am following the standard rule 3% or less for voltage drop as I have done for all my vehicle electrical projects.
I see all four working and I am planning on the rewire to follow #3 as it seems to be the most logical but, an alternative is #4, in this diagram I have transferred over the 3 fusible links to the starter battery, this does mean additional wiring work but as they are starting to look a bit tatty and were being replaced anyway I thought now would be the most opportune moment, I cannot see a strong enough argument to do the move though.
#1
#2
#3
#4
Your constructive critique would be appreciated.
Many thanks,
regards
Dave
#1
#2
#3
#4
Many thanks,
regards
Dave
