Greetings Mudsters,
I'm currently installing an Aussie Locker in the rear differential of my cruiser. I've run into a bit of a problem with the clearances between the cross pin and the adjacent washers. This is the 1st clearance check prior to installing the rest of the locker components. I'm not getting the recommended .006" - .020" of clearance. It looks to be more like .002". A .004" feeler can be forced in. Not sure if anyone has run into this issue before. most of the aussie install posts i've seen seem to have been a bit more straight forward.
Any ideas on easy tricks to try so i can do to get within spec? Wire wheel the coating off, file the washer surfaces, remove all grease, etc.? Or, should i continue on with the assembly and let the final gap measurement decide? If not, i guess i'm looking at thinner thrust washers.
and no, i dont want to hear about your spartan or paartrax locker, i already got my aussie sticker on the back window
