Posted in "what did you do this week" but thought it might go well here.
Just put on my bracket for the large middle skid plate (a long ago ordered diesel version).
Slightest misalignment of the forward mounting holes - about on the level of "maybe this got bent just a little in shipping or shifted during galvanizing."
Due to the robustness of the bracket it did require muscling it with a jack to get the bolts in the front - but I will just enlarge one or both of those holes next time it is off and it will be fine.
Perhaps also worth noting:
To simplify future installs and removal I used a longer center bolt for the front skid for two reasons:
If everything is aligned just so the supplied bolt is perfect - any shift and it's just too short to engage.
And my plan for routine installation of the front and middle skids is to support the middle of the front skid, loosely install the front bolts, loosely install the long center bolt in the front skid - this leaves space for the front of the large middle skid to fit between by rear of the front skid and crossmember and be somewhat supported, lift and support the back of the middle skid and get bolts started.
Seems important to be able remove and replace everything on the side of the road.
