Spent the day working on the wiring for this bumper; I was determined to figure it out and get it done. It took a bunch of different tries and as soon as I thought I had it figured out, something wacky would happen (e.g., amber light would randomly come on with the brakes, but only one of them). What I realized, is that the wires I'd soldered back onto the ARB wire loom weren't covered with heat shrink yet. The heat shrink was on the wire, but not covering the soldered part; I was getting all kinds of mixed signals because they were all in a bundle and touching each other
So, I moved the heat shrink in place and everything started working correctly. I'd tapped into the trailer harness when I realized my issue because I thought I'd at least get it back to what was working before. Then, one-by-one I switched to using the wires on the left side of the truck by the towing converter. It all came up roses then.
Here's what I tapped into:
For the tail lights, I tapped into the green wire on the left tail light as noted in
this thread. Once I had all that hooked up all the lights worked perfectly; signal lights were flashing at the correct speed, tail lights were lit but not super bright, and hitting the brakes brightened up the tail lights (no amber lights turned on with the brakes anymore).
Went back to the trailer harness and removed all the connections from the ARB harness to the factory wiring, patched up what needed it, and tested the trailer harness to make sure everything was good (it is).
Oh, and the reason the one signal was going faster than the other? I didn't hook the harness back up to the left tail light. As soon as I did that the signal worked at normal speed. Total blonde moment.
So glad to have this done. Thanks everyone for the helpful comments and suggestions (even when it was my own stupidity causing an issue
