ARB Drawer Owners...... I Have Some Questions for You. (13 Viewers)
I have had my drawers out a few times and I've tried to lube the rollers, but yeah they seem like sealed bearings. I'm in my drawers several times a day, had them since 2018, and they still slide perfectly, so I guess they are just maintenance free.
Yup, all my stoppers are broken. Dumb weak design.
What do the drawers do if the stoppers break? Will they come out of the enclosure?
No they won't come out but they will not stay in the opened position (unless gravity is helping). So if you are on an incline, they could close on you.
See image below. The main body will hold the drawer in place. What happens is the tip of the thin extension piece breaks off and it no longer can retain the drawer in the fully open position.
Yup, if you're parked on a slope nose-down, the drawers won't stay open. It's not a big deal, but can get annoying.
These little gizmos are available separately and are easily replaced.
I got my drawers used and needed to replace them, took 5 mins, not even a banana
I got mine from Slee, they are on his website, they were inexpensive
Had Dobinson drawers in my last rig. Would not buy them again. They take up WAY more space than the storage they provide. Overrated.
Take the top off the RD (8 hex screws IIRC) or open the top of the RDRF.
Open the drawer all the way.
There are two 10mm bolts on the inside back side of each drawer. Remove these and you should be able to pull the drawer completely out. Make a note of the orientation of the stops, including the direction the tab is pointing (towards the drawer handle I believe) and which side the bearing faces (towards the drawer frame).
Reverse the process to install.
This is how I fixed my broken stoppers issue, $2 each at Harbor Freight
Dang! I can use those on my Frontrunner drawers that don't have stops - genius!!
Thanks for posting!
(Definitely falls into the category of "Why didn't I think of that???")
