Noticed the same thing for mine... could be? They are only $80 (yes the HD) from RockAuto though and $14 shipping for me.When I go to order them it says not available online, call store. Maybe it's a regional thing?
Just FYI: The part number for the Cardone HD axle is 66-5185HD. This is the one with the thermoplastic boot. Currently listed at $69/axle on CarID.com, which with shipping comes out to $76/axle.Noticed the same thing for mine... could be? They are only $80 (yes the HD) from RockAuto though and $14 shipping for me.
When the time comes I will test mine and if possible post a video as I will be doing all that. Originally I had planned to do all the hub, wheel bearings, etc. first and then later do the axles but at this rate I might as well just replace everything at once and call it good instead of going in multiple times.Just FYI: The part number for the Cardone HD axle is 66-5185HD. This is the one with the thermoplastic boot. Currently listed at $69/axle on CarID.com, which with shipping comes out to $76/axle.
One thing that I forgot to mention in my previous post was that when I did briefly have that new Cardone HD axle, I test fit two new OEM hub flanges to it. It was a very tight fit, slightly tighter than a new OEM axle. Zero backlash at the splines for the Cardone HDs, and some although nominal backlash for the OEM splines (I did not measure backlash, but could feel a very small amount in the OEMs). I think the pressure angle used when machining the splines may be slightly different between Cardone HD and OEM. My anecdotal test fit of two new OEM hub flanges suggests the Cardone HDs have splines created with a wider pressure angle than OEM splines, which presumably could translate to the Cardone HD splines being slightly stronger than the OEM splines (i.e., wider pressure angle = stronger, but with diminishing returns beyond 45 degrees). I'm not a machinist or engineer, though, so this may all be![]()
Interestingly enough I was looking on the NAPA website and came across this!!
"An extra day this February means an extra day of savings. From now through 2/29 you save 20% on buy online ship to home purchases. Use code: LEAP20 at checkout to save."
Apparently, in one of the other threads someone was talking about how the GX470 crew seems to live and die by the Cardones, absolutely love them even more than OEM.
Mine is a similar story, PO replaced PS in June 2018 then DS in July 2018. Work done by 4WP in Vegas to the tune of about $300 a pop (labor was more than axles). Look back in my build thread for Alita and you will see the "type" of work they do. Doesn't surprise me that less than 2yrs later they are making noise, hubs have lots of play and will cost me probably a good $1000 when all is said an done to correct their work. Makes me think of FJ40Jim's quote from the 60 thread... His signature line says "Under hood janitor. Cleaning up other people's #$%& for 40+yrs."
Now I understand.
Interesting.... your rig lifted or anything else done other than the bigger tires (what size?)???I can only speak from my own experience, but here's my story:
I bought my LX 5 years ago, and immediately put some real tires on it and started wheeling it. It had 160K miles and only 2 previous owners, who maintained it meticulously and never abused it. Anyway, about a year into ownership, I noticed small cracks in the cv boots, and wanting to avoid any problems, I bought the Toyota OEM reboot kit. I had never done any axle work before, but I had the FSM and got to work removing and taking apart the CVs to clean, grease, and reassemble them. Well, when I opened up the joints, I discovered that my axles were not OEM. Instead of the Rzeppa design, mine were a tripod type joint. I had already put so much work into them, that I decided to just reboot these with the Toyota boots. My aftermarket CV tulips have a smaller diameter than stock, so it took some work to get the boots to tighten around them with the clamps supplied by Toyota. Also, I used the entire tube of grease in the kit, not thinking about my joints being smaller, so I did have some overflow squeezing out of the boots after a test drive.
But so far, I've put 70k miles (probably 20k+ offroad) and 4 years on these aftermarket CVs, and have yet to experience any failure or issues. If I had more money to spend on this type of thing at the time, I would have just bought new OEM CVs for peace of mind, but because I didn't, I'm a lot less afraid of aftermarket axles than I used to be.
I've been running 33" BFG KO2s since I bought it. I installed the AHC override from Slee shortly afterwards, and used it in high pretty frequently. I am now running a 2" lift without a diff drop and still on the same CVs. I have not gone easy on them either, and done some pretty extreme (for IFS) articulation, lots of towing and long distance driving, and plenty of desert trails at high speeds. Maybe I've been lucky, or maybe those who broke theirs were very unlucky.Interesting.... your rig lifted or anything else done other than the bigger tires (what size?)???
I got a follow up from Nitro and they just responded saying that it is a ball bearing type not a Tripod type CV. No other indication of what would make their axles special. So looks like I will be grabbing a set of the Cardone's when the time comes, navigating this slowly but should hopefully have everything acquired in the next month or so.
Certainly possible, since most people (non-MUD members) don't replace the hub flanges when doing wheel bearing job or CV axle replacement. I'd wager that most dealers don't even check the condition of splines in the hub flange when doing either of those jobs. However, I think the process of creating splines on the axle shaft being different between OEM and aftermarket is more plausible. For example, hobbed versus rolled, which could produce slight differences in spline width and depth. We need an engineer or machinist to chime in here!Could it be that Cardone figures the axles would be installed on older/worn flanges? In this case the wider angle might be set to work with parts that are not all new.
Some photos in this thread: CV Boots Replaced with directions I think we need somebody to use their lifetime warranty and chop up some of the aftermarket axles for comparison instead!I have a bad OEM axle in my garage I swapped out with a new OEM axle when it started clicking. I can cut the boot off and take pics if yall want them to compare it to the chinese axles from napa.
Sarcasm...I didn’t mean it literally.Chopping them would void the warranty.
