If your compression is 110 to 120 PSI. You've a bad engine. If he does get 110 to 120PSI when done with proper procedure. He must then due a wet test fast.
I'm sorry to say, your mechanic does not know what he's doing. All condition for a compression test I outline above, need adhering to.
Standard compression 192PSI or more. At sea level.
Minimum is 142PSI.
Difference 14PSI
I pull some parts off engine to get ready in advance. This way I can get spark plugs out faster. 30 to 40 minutes is okay for a good reading. But best is at 20 minutes. I can pull plugs, due a dry test and come back through and do wet test on all 8. In under 1 hour. That includes disconnecting fuel pump wire harness (under DS rear door near AHC rear globe)
Minimum is 142PSI.
Difference 14PSI
