Annoying P0430 need to solve it.
Bummer!
Can you list every DTC (code) that has been pulled from your system. Going back as many years as you can, in order as they appeared?.
OP may just have a small issue. Maybe just defective O2 or has a Wonky A/F, etc.... We can hope!
Many things upstream stream can affect the CATs. Wonky A/F's & O2's certainly can give a bad reading. Gas cap, fuel pressure, fuel injectors, MAF, Vacuum leaks. Those pre head or exhaust issue that may result in both P0420 & P0430 at or about the same time. Most of those should give their own DTC, but sometimes just don't! Why! I suspected they just aren't quite out of spec. Those "near out of spec" issues can add up.
With just a P0430 or a P0420 only, we focus more on that bank. P0430 is bk 2, so we focused more on head to rear of O2 in bk 2. Like bk 2 Vacuum leak (intake gasket of Bk 2), fuel injectors & seals, spark plugs, coils, valves, head gasket, exhaust leaks.
In OP's case, he's mention coolant loss. It's very import to identify this before proceeding. Not only could this damage CAT, but the engine. The concerning statements is he "didn't find". Every coolant leak I've seen, can be found externally on engine with time. Some, like at head gasket that "are" external can be very hard to see. I inspect each side of engine with flash light and a mirror. I do this with all lower and upper covers off. In the VVT engine seeing head gasket under intake manifold is not possible, without a camera. I use a $40 drain snake camera hooked/Wifi to my iphone. Only one I can think of, that can't be seen, would be into a cylinder. I'm not saying this is PO issues. But must be determined as a first step.
Second issue PO stated, was ticking after warm up. This may just be the fuel injectors ticking. But if and exhaust leak needs identified and repaired.
Also unless one has a virgin 100 series, never touch by anyone's hands. We've may have old procedure repair errors (mess ups) to contended with also.
Getting all in proper working order first, is key to P0420 or P0430 not coming back.
I've heard some say you can tell if a CAT bad, by thumbing on it with a rubber mallet. If something rattle bouncing around in it, it's bad. Well, yes I suppose if CAT fell apart. How would it fall apart. Impact for one. It can also burn up from within and fall apart from raw fuel dump in CAT. But that rich a fuel condition and cylinder temp runs cool. Maybe one or two fuel injector pump in excessive fuel could do this. Sensor read as rich and leans fuel trim of that bank. Yet that or those bad fuel injects just keep dumping excessive fuel. Also excessive leak down of fuel injectors. Then we start and dump raw fuel in cylinder could also be issues, I suppose. Excessive leak down is generally associated with long crank time to start engine. This condition and others related to fuel injectors are more seen with low mile engine. Engines that sat long period of time without be started or used bad fuels with water. Watching fuel trims can be useful tool. There is also a way to shut down a fuel injector with Toyota Tech steam SST tool. Unfortunately we can't do (that I've seen) with a $20 miny VCI hook up to tech stream.
So I have the p0430 code and I’ve just had the truck back for a few weeks now. Previously was sitting for a few months. Wouldn’t start. Turns out fuel injector fuse was corroded. Mechanic put a new fuel injector fuse in. A week or so later the check engine light came on. My 2000 LX is now just under 140k miles. The crank time for starting it seems to have increased. When I drive it, it sounds and feels pretty smooth until I’m stopped at a light or intersection, or in reverse; while stopped and/or in reverse, there is a vibration that is very apparent. Sometimes it’s less apparent but mostly very. Do you think this might have some to do with the actual fuel injectors?
Note: I’m 3rd owner. (As of summer 22) previous owner used it to drive about 2hrs highway to and from work everyday. He lived in a small city outside Dayton, Ohio. I now live in Cincinnati,OH and it’s been all city driving with the use of highways when needed.
Any insight here??
Probably was the EFI fuse, which was replaced. But that would not likely have anything to do with P0430 (BK2 CAT). It can be a wonky O2 sensor. But most times, the CAT is bad.
With a CAT failure, we need to look closely, for upstream possible issue. Also, not in flood or CAT has not taken a bad impact. Any exhaust leaks on PS side at or before CAT.
How's compression.
Any vacuum leaks.
Spark plugs & coils
Air filter.
How are the fuel trims (FT). I've been finding bad MAF sensors, damaging CATs. So often we do not get the MAF code. FT can be a clue to many things, including MAF.
Long crank to start. Is often excessive fuel injector leak down. When any engine sits long periods, it's tough on fuel injectors and fuel pressure regular.
Once also issues resolved. Run CatOclean or other CART cleaning product. Then heat CATs, by driving at 4,500RPM. If like turning your oven, on clean cycle.
Didn't want to start a whole new thread, and this seemed like one of the better P0430/0420 threads, so I'll just share my experience here:
Executive Summary: Fooled around with O2 sensors for a long long time then discovered an intake leak just before the MAF. Replaced air box, filter, and MAF and all seems good so far.
Long version:
About three years (30k miles) ago, I started getting P0420 every 200 miles or so (it was literally every Sunday for several weeks) in our 2004 LC with--at that time--about 190k miles.
For almost three years, I kept messing with O2 sensors--changed downstream ones one at a time, then changed upstream ones. Then kept getting faults--I'd switch the downstream sensors and the code would follow, so I figured I was just getting crappy sensors, so I bought genuine instead of Denso. Every time the fault came back on one side or another before too long. Then i'd swap sensors. Then I'd buy another. I could look at my maintenance book and see how many new sensors I put in, but I'm afraid to. (probably 4 or 5 🤪 )
I get oil analysis done by Blackstone every oil change or three, and they noted silica in the oil and said to check for intake leaks. The first time they said that, I gave everything a good eyeballing and figured I was good, as I had no other symptoms (or so I thought). But the second time they said it, it got me thinking, so, given that and the desire to figure out this stupid CEL problem, I had a shop down the street do a smoke test of intake and exhaust circuits. Sure enough--no exhaust system leaks, but a completely invisible crack at a joint in the lid of the air cleaner box. Rather than JB weld, I bit the bullet and bought a new box. I cleaned the MAF when I installed the new box and filter.
The CEL stayed off for almost 150 miles, but then it came on. So I read everything I could find on 'mud and a) replaced the gas cap (no dice, although the old one had seals that were clearly past their prime), and b) replaced the MAF.
Since replacing the MAF, the light has stayed off for over 250 miles so far, and the system reads "ready." Fingers crossed--Sure hoping this is the end of an overly long story, but still glancing anxiously at my instrument cluster pretty regularly...
Well, that was fun while it lasted. After about 300 miles it threw 0430 and 0420–I cleared those and 10 miles later it threw another (can’t even remember which it was.)
Im going to check all my spark plug torque and run an eye over the coils this weekend and then take it to a shop next week and have them look at the upstream and downstream O2 sensors to see if the cats are indeed perhaps just not working well. (I have techstream but can only see one set of sensors in there—maybe I’ll give that another try this weekend too….)
I suppose it’s possible that with the MAF getting at least a little dirty air running by it for 30k miles, because of that intake leak, that the engine was running slightly too rich or too lean, not enough to throw a code, but enough to make the cats wear out prematurely? It runs great, so I don’t think they’re clogged…
More to follow…
As promised, more info. Since my last post I have:
Checked all sparkplugs for tightness. Freaking number 6 was in fact finger tight, but tightening it and putting my new spare coil on that plug didn’t clear up the issue.
Replaced all four O2 sensors (the newest of them had around 15k miles on it, and with that intake leak and the MAF not working well, I assumed they were pretty fouled, both from engine mixture likely being suboptimal and from intake-leak dust in the exhaust.
This appeared to solve P0420 immediately, but P0430 faults persisted. After a lot of staring at techstream, it occurred to me to check the tightness of the sensors I’d just installed on bank 2. Sure enough, the downstream sensor was not even close to tight. Maybe a kid hollered at me after I got the nuts barely snug and I just wandered off.
Since tightening that, no errors, and techstream reports both banks catalyst efficiency passed with very similar numbers….hoping this is the end of the saga!
Summary:
Found intake leak at the top of air filter box letting air in between the filter and the MaF via smoke test at neighborhood shop.
-replaced filter box and filter
-Replaced MAF (genuine Toyota)
-replaced all four O2 sensors (Denso)
-problem apparently solved.
In hindsight I probably could’ve just cleaned the MAF and replaced the sensors, but that MAF had been eating dirty air for so long that replacement probably wasn’t the worst idea.
