- Thread starter
- #121
Rear 4 Link:
Frame upper links:
I would think I would want the 30* brackets, given the angles of the rear links. They also have a 10*.
Frame lower link:
This, or build my own cross member with mounts like @DangerNoodle. however, this is meant to mount to a atube cross member which would still allow the frame to flex whereas square would hinder and may have increased potential for frame cracking?
Axle Lower links:
Axle Truss and Upper Links:
Still considering this truss, from the quick reading I've done it seems widening the lower links is what has the biggest affect on body roll. I could also mount brackets further out on this truss.
Frame upper links:
Adjustable Frame Mount Link Bracket 30 Degree
Check out the deal on Adjustable Frame Mount Link Bracket 30 Degree at RuffStuff Specialties
www.ruffstuffspecialties.com
Frame lower link:
Lower Triangulated 4 Link Bracket
Check out the deal on Lower Triangulated 4 Link Bracket at RuffStuff Specialties
Axle Lower links:
3.0" Axle Mount 10 Degree Link Bracket Pair
Check out the deal on 3.0" Axle Mount 10 Degree Link Bracket Pair at RuffStuff Specialties
Toyota FJ80 Rear Axle Truss w/ 2.0" or 2.63” MW Upper Links
Toyota FJ80 Rear Axle Truss Link Mounts and Truss Combo Fits 94-97 Rear Axle Truss with Toyota FJ80 axle. Laser cut from 3/16" steel and faetures an oversized upper link mount surface. Includes optional upper link mounts. Ships un-welded. What's Included One (1) Axle Truss System Un-welded
www.ballisticfabrication.com
