Aisin secondary tuning ideas
CruiserTrash
Supporting Vendor
GOLD Star
Denver
Website
cruisertrashparts.com
There are already several great threads explaining 2F/60 Series Aisin carbs and what the secondary does, I’ll link those in the second post. So what’s the point of this thread? To discuss tuning the secondary to make it more useful. I’m just going through this and some of it is me thinking out loud, so feel free to argue with me.
After noticing my secondary wasn’t working, I set about to fix it. I rebuilt this carb a year ago and found two issues: the diaphragm was installed incorrectly, and the vacuum passage to the secondary diaphragm was plugged with gunk. There’s some cause and effect there. Oops … my bad.
I’ve had several carbs that work fine on my 60s and noticed that even when the secondary is working perfectly, it rarely opens. I live in Denver and the secondary will come into play driving up long highway grades in the mountains, that’s really it. An effect of lower air density at altitude? Not sure. Even the carbs I’ve gotten from low altitude places have squeaky clean secondaries though. In all other circumstances I’m always having to shift gears before the secondary can build enough vacuum to fully open.
A couple of facts about the secondary, carbs, and engines (see the linked posts below for deeper dives):
-the primary linkages mechanically crack open the secondary a very small amount; this enables the next step
-the secondary then fully opens via a vacuum operated diaphragm & linkage; the vacuum comes from inside the venturi, there’s a passage near the secondary butterfly that sees a vacuum when the butterfly is cracked open
-the engine is an air pump, the carb is an imposed restriction so you can control the air pump
-the carburetor deals with flow of air and adding fuel to that flow; the secondary opening fully based on vacuum has to do with that flow; power is, among other things, also related to this flow. More flow = more power (obviously there’s more to it, but this is what I’m focusing on)
-other things control that flow like intake & exhaust valve size & timing, head design, and displacement, but that’s beyond the scope here
So how can I shift the secondary’s contribution to air flow down into the usable range a little more? How can I do that without sacrificing the secondary’s contribution higher up? I think it’s a balance! I use the words down and up generally to reference both rpm and engine load. We can start by looking at the carb rebuild & setup procedures in the FSM. There are three key things here: how quickly does the secondary crack open, how much does it crack open, and - not mentioned in the FSM - how quickly does the diaphragm make it open fully?
1. The initial cracking open of the secondary happens mechanically by action of levers connected to the primary, and ultimately connected to the pedal. In the photo below the circled tab controls how soon the secondary starts to crack open. Bent way down as shown will start the secondary moving sooner than what’s specified in the FSM.
2. How much the secondary gets cracked open is controlled by the lever circled below. There is an arm attached to the primary that contacts that lever. Bending the circled lever upwards will make the secondary crack open more, but be careful: if you go too far the butterfly will be open at idle. This is not good and tuning your carb to make the engine idle nicely will be difficult or impossible. I went right up to that point, stopping my adjustment just before the secondary was open at rest. In total it now opens about 4-5mm. The spec in the FSM is an angle of the secondary and it equates to about 1-1.5mm of space between the venturi wall and the butterfly. So now there’s more air flow mechanically, under your pedal foot.
A couple notes here … the shape of the arm attached to the primary - the one that contacts the lever circled above - is rounded and kind of horizontal to the axis of rotation. This limits the total amount it can effect the circled lever. If it were shaped differently, it could crack open the secondary more. Also, because the circled lever is so short (left to right), the arm that contacts it can partially slip off the right side, causing the secondary to go just a smidge more closed. This wouldn’t happen if the lever were longer. Out of all the carbs I’ve had on my two 60s it always feels like it makes the most power when the pedal is just a hair back from hitting the floor - I wonder if this is why. It’s a very, very slight feeling.
3. Last is how quickly the diaphragm pulls the secondary fully open. I haven’t gotten into this yet but I think there are a couple ways to adjust it. Inside the diaphragm is a spring, and the vacuum has to pull against the spring pressure. The hot rod carb companies like Holley and Edelbrock make spring kits for this - you get a package of 5-6 and do trial and error until you find one that works for the goal. I have a set of those on the way. Second is the small orifice in the casting that holds the diaphragm. It’s there to restrict vacuum flow. I wonder how boring out the orifice would change things. My initial thought is that the orifice controls how quick or how “snappy” the diaphragms actuation is. I think both of these need caution: if the secondary opens too fast you’d probably get a momentary bog as air rushes in through the carb and fuel isn’t quite being pulled into the venturi yet. It would be a split second thing, but a stumble nonetheless. Probably why some hot rod carbs are “double pumpers” and have an accelerator pump for the secondaries. I’m going to go lighter on the spring pressure until it stumbles, and then go back one spring heavier. If the diaphragm snaps the secondary shut too quickly, you’d probably feel the truck lurch a little bit when you relaxed on the pedal, too. Not good. I’ll leave the orifice for now but might come back to it. Here’s the orifice/restriction below, it’s a brass piece pressed into the vacuum passage in the diaphragm housing:
So by adjusting the lever arms in #1 & #2 I now feel a little more juice around 1800 rpm, and I can feel a little more above 2800 as well. This is a 2F, so it isn’t much - but there’s a little something more that I can feel. Prior to this there wasn’t much beyond 2800rpm or so, unless I was climbing something like Vail Pass. Even then it wasn’t enough extra to keep me from losing speed for a good length of time (as the secondary is probably pretty slow getting to full open). That is a definite downward shift (rpm and load) in the secondary putting in the work. What I don’t want to do is have the secondary fully come into play too early and have nothing left to give in a Vail Pass situation, or needlessly chew through fuel driving around town. So far this has made a decent amount of difference getting onto the highway, but I haven’t done a big climb since yet so that’s TBD.
Thanks to @mattressking for letting me bounce ideas around and @RDub for the same, for half-assed going through Bournouli’s equation with me, and for generally geekery as usual.
Alright, time for y’all to tear apart my ideas!
This is great! I went down this rabbit hole too last year.
@CruiserTrash - you probably saw these but also some interesting stuff buried in them:
The latter the as I have seen. The first thread I have not … and I’ve searched on this topic for a few years! No idea how that one eluded me!
What did you find last year? Any tips? The first post is just me thinking out loud, I’m not an expert (and I don’t play one on TV, either).
@CruiserTrash, put down the carb cleaner and get to a well ventilated room. Everyone knows carbs are voodoo black magic. Save your soul before you get too far down the rabbit hole.
Maybe I’ve been huffin’ too many gas fumes from these things
I felt the secondary start to fully open today. Short highway drive, steep merge ramp from one highway to another. I was at WOT in 3rd gear going about 40mph, and felt it after about 6-7 seconds. At the same time my A/F gauge dropped from 13.5 (typical for me at WOT) to about 12.25.
Found this when I got to my destination:
Not fully open, but it moved! It didn’t so much feel like speed - more like grunt.
I've fought this a lot the last year or so as well. I tried multiple carbs, multiple springs, multiple diaphragms. What I finally found that worked was a specific carb set to the FSM recommended kick up and primary contact angles, adjusting the two tabs you mentioned above. Funny enough, I did the exact same thing on another carb, and no dice. I found that the amount of paperclip movement in your photo above really was just from the mechanical linkage kick up, and not the actual vacuum device pulling the secondary butterfly open. Once I found the winning combo, it pushed the paperclip down about a half inch or so.
Another interesting addition I found - once the secondary actually started working for me, I found the secondary fuel cut valve finally started leaking after years of laying dry and dormant - that was a clue that I was on the right track and fuel was actually flowing into the slow jet of the secondary. Additionally, I found that because of that leak I'd get a weird bog in city driving scenarios. All that was solved by the common solution of gutting that secondary slow cut valve and tapping it for an M8 bolt.
@ryyount Great info. I wonder what about a specific carb made your vacuum secondary work versus other carbs set up the same way. I've heard things like:
-Make sure the vac passage is clear from the venturis to the vac pot. I consider that part of a cleaning & rebuild.
-Make sure the gasket between the bowl section and base of the carb is installed the right way, since the vac passage runs on the bottom surface of the bowl section (I wonder if oiling that part of the gasket would help). Here's a photo stolen from @mwebfj60:
-The new diaphragms have a bonded gasket so don't use the separate gasket in the kit
-Use the extra gasket anyway
-Where the secondary vac pot bolts to the carb, use the small paper gasket dry
-Soak the gasket in oil first
-I've thought about a small rubber o-ring there - it would get compressed as your attach the vac pot to the carb
Regarding the secondary slow cut with it's little pump action ... No replacement for that boot of course. I tried to adapt an accelerator pump boot from City Racer, but it didn't work at all. How does the piston seal inside the boot? I've never taken it apart to look. I read the thread on that bolt modification a long time ago, but I can't recall what that did. Is that valve in place just to keep residual fuel from weeping into the secondary when it's closed? And the bolt allows that passage to be permanently open? Does any fuel weep out inside the venturi as a result? Is the function as a sort of transition for the secondary as it opens?
I couldn't for the life of me understand why one worked and one didn't. I did the exact same procedure and made sure all the vacuum sources in both Venturis were clear. Once reassembled, I even sprayed carb cleaner through the vac port where the diaphragm bolts on to make sure it was flowing through both Venturis. I'm still playing with mine, I'd like it to open a tad bit sooner, as it's definitely at the last few inches of my accelerator travel (probably intended this way from stock.)
You're correct on all accounts for the secondary slow cut valve. The arm pushed down by the throttle linkage opens up the valve (I believe at around 50% throttle). Its only job is to restrict fuel from entering the secondary slow jet before it's needed. Haven't noticed any extra fuel going anywhere, as I've confirmed the secondary butterfly is totally closed until opened by linkage, I believe this valve was just yet another emissions component. Process for gutting it is pretty simple. There's a pressed brass cup that the steel piston goes into. When the rod is depressed, it pulls that piston up and allows fuel to flow. Pulling it apart and tapping it with a short bolt just lets the fuel flow freely, as long as the bolt is not in the way. Funny that the fuel literally leaves the carb body, into another valve, then back in.
Yeah the path is pretty circuitous! I do remember from that thread not to run the bolt in too far or you’ll block fuel flow. Might be time for me to do that modification.
The manifold vacuum, at altitude might be prohibitive for the carb? More so than air-density, my 2F will make less manifold vacuum, here at 7,000-feet. The issue there is the throttle needs to be opened more to get the same mass of air thru the carb. So, if the motor can pump it thru the intake, the carb will deliver, but, it won't work when vacuum falls past a point - hence the vacuum-governed secondary.
My Datsun Z24 has a Weber, which is purely a mechanical secondary (progressive-akin to the Aisan). The worry is that I'll open the throttle too far without enough vacuum, and lean-out the mix while struggling to make higher rpm-power.
I'm thinking about fuel droplet size, high-altitude spark timing, and ring-seal to help the carb work like it should.
There’s definitely lots of other factors at play here, and you’ve provided a good list. My idle vacuum at 5300’ is 17inHg. That’s after lots of fussing, idle speed around 750rpm, and it’s the best I’ve been able to do in years of twiddling. They say at 5000’ you’re down 18-19% on vacuum compared to sea level, which means my truck would probably have an idle vac of 20-21. That seems healthy.
But at max 17, I definitely have to open the throttle plate wider to get moving versus somebody might have to at sea level. The max vacuum is really just serving as an indicator of the air being less dense - which means less combustible mixture in the engine. Thus you’ll have less power, and you’ll need to open the throttle up to make up for it.
Now, the vacuum secondary is operating off of venturi vacuum and not manifold vacuum. As the air rushes through the bore, it generates a localized vacuum at the port leading to the secondary diaphragm. That’s regardless of inversely proportional to manifold vac.
You’re right that if it opened too soon or too quickly, the he engine would fall on it’s face from going lean. The secondary does have the second slow cut circuit though, which is supposed to help with the transition as it opens. Whether or not that could keep up with a really snappy secondary … I don’t know.
It might not be related, and you might have already heard me talk about it in the 40/55 forum, but, the new Valvoline Restore and Protect has been in my crankcase since December, and I've experienced performance gains, particularly for driving when cold. Carbon deposits compromise piston ring-seals.
I'm had a couple of F-engines in my '73, and now the 2F in my '75. Headers on all of them They all were throttle-sensitive in the cold. I think the Valvoline product might be a solution to a carbon issue in a relatively low-compression engine?
Springs arrived. I’m going to install a yellow one this afternoon. These came with all the springs meshed together in shrink wrap. It took more time to get them all apart than it will to install one.
Oh, and I’ll test on a gram scale first, the original spring too.
There is a torsion spring that maintains a closed-position on the secondary. Can it be unwrapped one turn, and will that change how much vacuum is needed to open the secondary butterfly?
Nice! Let us know what happens. I bought the same kit but never got around to it. I know folks in the past have posted using the white one…
Ended up pulling the carb off the truck. I just wanted to check it out and verify vacuum passages. All good there. Looks like maybe there was a leak at the phenolic spacer though.
Bonded gasket looks good. When I rebuilt this a year or two ago, I remember the one in this carb was failing, so I looked pretty hard to find this good one.
Decided to run the paper gaskets anyway. Made sure I carved out the two extra holes that were missing, as well as the holes that are slightly misaligned. And the carb bores too, the holes in the gasket are smaller and would impede flow.
Did some vacuum testing on the secondary diaphragm. This is how far it wants to move all by itself with the original spring.
And this is how much it’s been moving - all from the mechanical kick up. The diaphragm action wasn’t happening at all.
About to go test drive it.
