Customer went 9000 miles between intervals and used a different brand of synthetic oil every time![]()
Why would switching synthetics have any consequence?
Wow, crazy pics. Thanks for showing how truly ugly sludge buildup can get.My last Blackstone report suggested that I push my intervals to 12,000 and I'm running conventional oil, so I wouldn't worry about going further on synthetic
That being said, I think it has more to do with the fact that the 1FZ is very easy on oil when compared to other engines
Here's a Honda Odyssey motor I tore down after the cam gear snapped off from seizing up
Different manufacturers often use additives that aren't always compatible and can actually produce sludge
It's always best to choose one brand (whatever it may be) and stick with it for the life of the engine
*sent from my android string cup*
98 SNAKE EATER said:Different manufacturers often use additives that aren't always compatible and can actually produce sludge
I thought synthetics is suppose to clean out sludge. If indeed switching to diff oils over a lifetime of an engine produces sludge then everyone here is screwed. Most 80s have had multiple owners and what are the chances that these owners all use the same oil?
I am unconvinced that there is any compatibility issue with various oil additives in motor oil. I don't know the qualifications of people who are debating this on oil forums but I have seen some completely baseless discussions reach conclusions on the internet that have no connection with reality. So, might I suggest that those suggesting there is an issue are not as well informed as they suggest?
I used to develop vehicles for GM and for Lexus and Toyota and was also Worldwide Powertrain Planner for GM. We used to routinely test oils for our engines in all manner of lab and real world conditions and I've never heard of this.
On the common sense side of things, if you do an oil change you are swapping out perhaps 95% of the old oil and the additives are such a small % of the oil volume itself, we are talking about remaining additive quantities that would fit in this period. And if a mfr were using an additive that in that small a quantity could cause issues, then it would be an incredibly potent and incompatible substance indeed. No way the Petroleum Engineers and SAE standards would allow an oil to be approved with it. So, I'm trying to respectfully say there is no way what the people on the forum contend is true. Absolutely no way residuals from one oil cause any issues with another oil. The whole point of the oil approval process is to ensure this incompatibility cannot take place, and that oils are uniform.
So get back on those forums and tell them they are full of BS!! Heh...
DougM
Subscribing to see the results of your report. I predict it'll be just fine. In the BMW world 15k oil changes are the recommended process even in high performance applications like my m5. Most enthusiasts don't adhere to that...I change mine every 5k or so...but I doubt that a quality synthetic will be destroyed in 13k.
Sent from my DROID BIONIC using IH8MUD
