- Thread starter
- #61
Sweet I have a bunch of an fittings laying around. I dig through them. Pretty sure I have some 16mm from a 2jz buildI high-pressure fitting in the Type 2 Saginaw pumps (what you have) isn't flared, it's an O-ring.
The Pressure fitting in the steering box is an inverted flare though.
I recommend getting adapters to -6AN for the box and pump and just running an AN or JIC style pressure hose. That way you don't have a custom hose to replace in the future.
16mm flare for the box and 16mm O-ring for the pump. You can get the O-ring adapter anywhere easily, the 16mm Toyota flare adapter is a bit less common, I think I got mine from PSC.
