- Thread starter
- #581
So with 200# dead center there is 1/8" clearance at the highest point of the roof. Thats on one cross bar with no supporting structure so I wonder if I'm too low?
thetoyotaman said:That looks great and if one support holds 200# you will probably be ok. The only thing I can think of is that you might want enough clearance to put your hand underneath for tying ropes and cleaning. Low profile is the way to go though. I ripped my roof rack off a couple of years ago on a low hanging tree. Luckily no damage occured.
Henry James the 47th said:What will the tent be sitting on - a plywood deck? Can you consider the stiffness of the tent floor deck as part of the 'equation'?
.i like 3/4" under the tightest spot on the racks i make ... but that is just me.
are you interested in selling these cross bars?
Just a thought here Kevin: my old rack on my hilux years ago was pretty close and I would occasionally get ice buildup between the rack and roof which led to some ugly wear to the gel coat on the shell. I'd consider more like 1/2" personally to allow for a bit of flex for ice to break away.lowenbrau said:That square section, rub rail is spiffy.
Based on the fact that there will be a bunch more support I think your tight tolerance is probably just fine but a bit of heater hose or pvc tubing on the gutter side of the towers would probably make the seam sealer in the gutter happier and give you an additional 1/8"
Excellent point Josh, thanks.
