Hi, Try a stethoscope and see if you can pin point the noise. When's the last time the water pump was changed ? Can you wobble the harmonic balancer when cool and engine off by hand ? Mike
Well when the motor is off is hard as a rock, i just did a timing chain replacement, i don't have the torque wrench and i did torque by hand... may be as many of you suggested is not real tighten...
you need to pull the front of the truck and get a straight look at the HB and remove, then inspect. If it has been loose for awhile it can ruin your crank.
If that the case is have been loose for a few weeks after a timing chain replacement, but i haven't been driving it and i won't till i solve this, i had been turning the engine on just to inspect and do motor flushing like 10 min at a time, at the same time i flush the brake lines and tested so one day i did accelerate and brake hard to test the brakes but that was less thatn 20 min...
What happend was, i have an oil light, check the level and everything was fine, so i was guessing the sensor went wrong, but later the timing chain start to knock i thought it was a guide broken so i bought a Timing chain kit, when open it up i saw the guides and chain were fine, but, the car had a real bad oil gunk problem so the oil light was trying to told me that, maybe the previous owner was mixing mineral oil with synthetic or something because is was like Tar so maybe it was that oil wasn't getting to the tensioner, so never the less i put the new chain and clean everything the most i can and do several motor flush till the oil wans't getting black. at the same time know that i was working with the engine open, i move to do everything that needs to be care off, the loud Knocking sound coming from the timing chain was gone, but left with that little one, and yesterday i saw what i recorded on video...
i was going to take the tensioner out and try to clean the oil lines going to the tensioner but after your advices i think that i have to find a way to torque the HB bolt at 304 lb, how can this be done with out a torque wrench is my new question mark.
