We have a 1971 FJ40 completely stock (three on the tree) that we're trying to bring back to life. It was running great for about 150 miles this last week, but all of a sudden, its now bogging down and bucking in 2nd and 3rd gear at higher rpms with backfires out the tailpipe. The fuel lines have been cleared and the fuel filter replaced. Fuel level appeared good in the carb window, and the carb solenoid does click. We tried running it without a gas cap and that didnt help. The engine runs flawlessly when revving it up with the clutch pressed or while in neutral, so I assume its not fuel starvation. I don't think its a vacuum leak (at least not anywhere you can check with starting fluid) The points and rotor looked fine on the distributor, but there was some play in the rotor. How much is normal here? If its not the distributor rotor, then do these symptoms match anything else? Could this be a failure of the vacuum retard? What about the coil? Any other ideas?
