So after 12 years I'm going to upgrade my 40 (1971)! I'm removing the stroker (383) and installing an all aluminum 6.2 litre. Removing TH400 and Toyota T-case and going 700R4 & NP241, and going with GM 1 ton axles. I'm narrowing the front 60, and have C&C hubs for the 14-bolt. Ditching the 35's and going with Hutchinson beadlocks and 40's. I want to keep it low and flexy! First off, what springs (leaf) should I be considering (spring over)? I was kind of planning on running FJ60 rears all the way around, but I want to make sure I'm going the best route possible as I don't want to do it twice. I've been running 4" Skyjackers for 12 years, and I think they have about 3" of total travel and ride like s***--but it corners great! I've already got tube fenders up front that should clear the 40's no problem and am going to clearance/modify the rear. The other question I have concerns the Dana 60. Do I have to cut and turn the C's? Remember, this is a GM 60 so it has the spring pad machined into the front housing. In all of this, I want to extend the wheelbase also, and it seems like the 60 springs do that also. I do have the 25 gallon auxiliary tank in the rear and that is my only tank. Is that going to be an interference problem with the 14-Bolt? Anyway Fellas, thanks ahead of time for any information you can share!
