62 Long Range Fuel Tank Pump Options
North Idaho
I'm finally gonna bite the bullet and fork out for a bigger fuel tank now that I now have reason to suspect my 15 year old fuel pump is on its last leg anyways. I might as well replace the pump & strainer simultaneously and would like to hear any sucess/ failure experiences of a replacement pump whether it is aftermarket vs OEM as well as suppliers. I know I am limited on options and being this mod is at the upper end of my budget I need to get it right the first time. Any comments or concerns I would appreciate. Thanks
gbogh
Chelan WA
IMO unless you have a significantly modified engine, get an OEM pump or OEM supplier (Denso) pump and be done with it for another 15+ years. Trying to save <$100 to potentially have to go back in your fuel tank to replace it isn't worth the initial $ savings
HemiAlex
Long live the 2F
Supporting Vendor
GOLD Star
Houston
Website
yotaoilfilters.com
@tmxmotorsports makes a ring to use a better pump module in a long range tank. One day I’ll buy one from him.
North Idaho
That's what I needed to know, Thanks. I wasn't quite sure if OEM was still available.... I have noticed quite a fluctuation in prices on OEM parts- e.g. dealer vs parts houses. It is always the safest bet to check with fellow mudheads before shelling out bucko dinero to the dealer.
FishNinJay
Orange County, CA
Have you finished this? What long range tank did you go with? And Toyota OEM fuel pump?
I'm wondering if I'll end up doing this.. if I can't get my 1990 FJ62 tank serviced under the Toyota tank recall.
