One of the downsides to running w/o the backing plate is that the road grime thrown around under the truck ends up reducing the lifespan of the inner brake pad by getting on the inner rotor surface. The other deal is that the rotors are designed to pump air from the center to the OD. Doing away with the backing plates won't affect this much, but it will result in differential cooling of the rotor since the backing plate approximates the cooling restriction that the wheels have on the outer wear surface of the rotor. The hotter that your brakes normally operate, the more this is significant.
If you do a lot of highway miles I'd suggest leaving the plates alone.
If yours is primarily a trail machine then have at it.
If you really want to increase brake cooling, modify the backing plate to duct air into the center of the rotor right at the wheel bearings. I have seen scoops built onto backing plates and ribs added that form a bit of a labyrinth seal at the ID of the rotor's inner surface. If you do make a scoop I'd suggest some wire mesh over the opening to keep the gravel out.
