if you are just looking for extra power I think you should just buy a gt35r or supercharger for your stock engine it is less money and time and you will be happy.
The sound, in terms of decibel readings, is probably close to being the same, but the harmonics of the engines are different. The 6bt is smoother due to the inline 6 design. The 4bt is a very "rattley" engine if that makes any sense at all. You would understand if you have ever been around them. They are used in industrial equipment including Case skidloaders if you have ever operated one. Lots of people get the engine out of bread trucks. I believe there is an Advanced Adapters adapter which runs the stock case. All you need should be engine (and mounts) and a tranny.With a 4b or 6bt, is there an adapter to run the stock transfercase in the 80 series? Wouldn't the offset rear axle could pose a few problems?
Also, is the 6 any quieter than the 4 in the older 12 valves?
Thank you,
Adam
i'm not saying diesel motors aren't cool, last a long time and can run on veggie juice, but saying that the 1fz if properly built and turbo'ed or SC is not up to the task is just wrong.
I"m not trying to be argumentative.... but i can't see the gas mileage on trails to be significantly different. I can easily be wrong!
I will get off my soapbox, but think that all the stuff is there, working, computer in place..... just add some forced induction, bore it out to a 4.6 and be done with it for another 200,000 miles.
I have the 6BT in my motor home, it's a huge very heavy engine does have plenty of power, i was stopped in Nevada on rt 80 doing 98mph with a 41,000 lb rv. trooper let me go without ticket. I think it's way too much engine for a small 4x4My vote is for the 6BT. Your 80 came with an inline 6 and would like to stay that way. It is a smoother powerhouse. Intercooler placement will require ingenuity but IMHO is worth it. Frame should handle the 6Bt in stock form. Recommended: 94-97 12 valve p7100 pump KDP tabbed.
