40 series general tech and classifieds (1 Viewer)
I must be crazy; I actually like the steelies.
Easily the best looking (non-40-specific) steelies Toyota has ever made...
Out of curiosity, if your were a 40 buyer today, what's the max you'd shell out for your old 40?
If it were me personally, I am extremely cheap. There is no way I would pay $30,000 for that truck. Maybe $15,000 or $20,000. Honestly though, I do believe that truck is worth what the guy is asking. The mechanical and electrical are well sorted, and that engine swap, is still one of the cleanest I have seen. I think he should be able to get at least $25,000
I’m not sure why Toyota went away from these hinges but pulling a FJ45 top is some kind of easy. 4 bolts. Short alignment shafts. Lever hinges.
Roger Claus making a delivery just in time. Thanks to city racer llc for a little much needed hardtop love this christmas.
Hate i did not see that cruiser brothers were $110 more than Kurt for the exact same set of 80 spindles. That alone woulda afforded me the last piece of hard top rubber i couldnt pull the trigger on :(
1973 FJ40 Rock Crawler
$17,000
Lafayette, LA
For Sale:1973 FJ40 Trail/ Crawler with an Aquala aluminum tub.
Drivetrain: V-8 2UZ motor and automatic transmission out of a 2000 Tundra, Inchworm Prerunner adapter to a 4.7 geared twin stick mini truck T-Case.
One Ton Axles: Front CUCV GM Dana 60 with ECGS drive slugs, ECGS chromoly axle shafts, Detriot locker with 4.56 gears, and 1/2" diff gaurds.
Rear CUCV GM 14 Bolt, disk brake conversion, Gov't detriot locker 4.56 gears, pinion guard and 1/2" diff cover.
Suspension: Front sprung over with FJ 40 leaf springs, Rear 4 linked with TJ coils, and Rancho 9000XL shocks on all 4 corners.
Steering: High Steer arms, hiem joints, hydraulic assist with Red Neck ram and tapped Sagnaw box powered by PSC pump and resivior.
39" BFG Sticky Krawlers on H2 wheels
White Knuckle sliders
Lifetime LED headlights, rock lights, and reverse lights.
No hard top just a bikini top. MetalTech and Full doors.
Etc....
Build thread:
https://forum.ih8mud.com/threads/2uz-fj40-on-cucvs.596448/…
Asking $17,000. Will take partial trade on 4wd Tundra/ Tacoma double cab.
44800687_1969094599803400_2282575105491992576_o-jpg.1860976
44779520_1969095526469974_5134801065006333952_n-jpg.1860978
9194_927054964075731_3638791492416295242_n-jpg.1860979
Asking here because I thought it might be seen sooner. Anyone know the proper size of the vacuum lines going to the transfer case on a 3spd case with vacuum actuated 4wd. I cut mine while pulling the case and need to get some replacement hose. @wngrog @MScruiser @orangefj45 @offr0adlim0 @beno
Thanks in advance
Thanks, i meant to pull them while i had it out, but forgot, so now I gotta try and swap the hoses I cut when i pulled the case.
Sorry, my 78 does not have a 3spd
Thanks in advance
If it’s similar to the 62 3/8 will work.
